Diopter and field of coverage (SORRY!)
Started by waterwookiee ·
  1. SORRY, to bring up an over-discussed topic, but I just cant' find my answer by searching.
    I know that I diopter lessens the distance a lens can focus, but what effect does it have on the angle of coverage the lens has?
    Say the Nikon 18-70 DX covers about 70ish degrees on land with no diopter. So when you put on a +2 diopter, what is the angle of coverage? Does it change, or just the focusing distance? How much of the "wide" is lost?
    Thanks a ton.....!!! ;-)
    Happy diving,
    Scott
  2. Adding a close up filter decreases the effective focal length. So it should makes your wides wider.
    How much the focal length changes?
    EFL = 1000/((1000/FL) + DP)
    1000/((1000/18)+2) = 17.37 | 18mm lens and +2 diopter
    at 18mm it becomes 17.37mm
    Edited by acroporas
