Macromate size
Started by Matetes ·
Macromate size
  1. Hi
    I would like to buy a Macromate for my Hugyfot flat port... :) But Hugyfot is not in their list.... So, I would like to know the measure of the outer circumference of the following flat ports:
    -Subal
    -Seacam
    -Aquatica
    -Sea&Sea
    Maybe I can use one of the macromates offered for those brands... :)
    Hugyfot's flat port external circumference is 37,5cm (14,57 inches)
    BTW.- I already sent an e-mail to Basckscatter with no answer so far.
    Matetes
    PS.- I've just got an answer... They say: there isn't any model for Hugyfot. I know, but I want to know if I can use any other model (making some DIY...)
    Edited by Matetes
  2. What I mean is: could any proud owner of a Subal-Seacam-Aquatica or sea&Sea housing measure the outer circumference of his flat port and tell me the result?
    Thanx
    Matetes :)
  3. The diameter of mine is 115 mm so the circumference should be 361 mm by my calc.
    BVA
  4. Thanks Bvanant... Could you tell me which brand are you using?
    Matetes
  5. I have Sea & Sea's and Subal's on hand, they are:
    Sea & Sea: 36.91cm
    Subal: 35.97cm
    I checked Light & Motion's as well but it tapers from 35.2cm to 35.7cm
    If you don't get the answer elsewhere I can check the Aquatica port in a few days. Send me a PM.
    Edited by UWPhotoTech
  6. According to my trusty tape measure, my Aquatica port measures 40 cm; and I LOVE my Macromate! :)
  7. Thanks a lot...
    Matetes
  8. The Seacam Ports measure approx 376mm in circumference (could be a couple of mm either way).
