top dawg housing
Started by newvideo ·
top dawg housing
  1. HI I DIVE ONLY A FEW TIMES PER YEAR AND HAVE BEEN LOOKING AT BUYING A USED TOP DAWG HOUSING FOR A HI8 CAM AND MAY BE LATER UP GRADING TO MINI DV. ANYBODY HEARD OR HAD GOOD OR BAD THINGS ABOUT THIS HOUSING THANKS
  2. I rented one once. Build quality was very good. They are made by Light & Motion. That means you a nice, well-made aluminum housing. It used a double o-ring on the back. The drawback was that the front port is flat. If you use a wide angle lens you may get some vignetting.
