buoyancy
Started by petr ·
buoyancy
  1. Hey Guys,
    how do you deal with the possitive buoyancy of the housing when do you use the 8 inch port. I add the lead into the bottom handle base, but the port still flip the system up.
    I thought to add a piece of stainless steel to the handle base and add another lead just under the port....so it will move the centre of gravity to be more neutral. Have someone tried this out?
    Thanks.
    Petr
  2. Sounds like a good idea. I use an ankle weight strapped around the handle base.
  3. Does it work well or it has a tendecy to flip?
    Petr
