focus light for Ike D70 Housing
Started by gianster ·
  • 34Posts
  • 34Replies
  1. since the S2 is probably the first generation DSLR housing from Ikelite, i expect to see the slot available in every subsequent digital housing offerings from ikelite.
    I was wrong.
    Eric
  2. Note #9571.23 clamp with side stud on following URL:
    http://www.ikelite.com/web_pages/arm_f.html
    Ike, How I wish you would make a mount for the PCA or PCM. The mini C is a good light but now I limit all my battery eating goodies to AA. Small batteries and small chargers! The Airlines have made this even more important with their new weight restrictions.
  3. Ok, good point about the problem of moving the strobes and focus light at the same time with the tri-clamp. How about using the 9577.71 here : http://www.ikelite.com/web_pages/arms.html...pages/arms.html
    and mount one strobe to the bottom of the tray and the focus light to the top of the handles on a small arm. If you want both strobes the same you could mount them both to the bottom of the tray.
    This might also solve the problem I occasionally have when I hand my camera up to the divemaster and the quick release comes detatched.
  4. Chris Bangs,
    Here's a link to Thomas Distributing for a AA to C battery adapter. I've used them for the last couple of years and they work great. This allows you to use AA batteries in stuff that require c batteries.
    http://www.thomasdistributing.com/nc-c-adapters.htm
    Edited by bondo
  5. I just had a conversation with Ryan Canon about this very subject. I ordered the #4074.1 that will mount to the bottom of the strobe arm at the housing handle (Like the Manual controller does for those of us that used them before eTTL). That way I can position the strobes without moving the focus light, at least thats the plan ;) !.
    I'll let you know how it works in a few days B) .
    Dave
    Edited by dwloop
  6. I use Ikelite's holder for a Mini C light mounted in the first segment of the arms conecting to the housing handles. You just need to get the long ball posts as they give you more room to place the light without getting in the way of your arms.
    The light can be placed in the inside of the handles going almost over the port or in the outside coming to an almost 45 degrees angle to your line of sight .
    The mini C lights have a little of a "hot" spot but sliding a thin clear plastic sheet between the front ring and the lens difuses the light enough for very close shots.
    The other advantage i find was price, the light is less than $40 and the holder is about thesame. You can remove the light easily under water if you need to use it as a dive light with one hand.
    Hugo
  7. Already have the long ball mounts, I was using a manual controller before I got the coversion to eTTL.
    Thanks for the tips! I didn't want to spring for a $425 special modeling light right now... ;)
    Thanks again!!! :angry:
    Dave
  8. Stay tuned, Ultralight has something in the works for adding spotting lights to their
    arms and base adapters, even those that fit into the Ikelite handles. Might be 6 weeks or so as it is still on the drawing board; but will be a reality.
    Triple clamps do ok if you dont need to move one of the three components but as soon
    as you loosen it then all three balls move ;)
    I will keep you posted.
    Terry
  9. Already have the long ball mounts, I was using a manual controller before I got the coversion to eTTL.
    Dave
    Manual control rules! I would not abandon the manual controller if I were you. TTL is convenient but it does not work well in all situations.
    I also look forward to seeing what Terry has in the works. User request! forget the Velcro retaining system. After losing two lights I started using electrical tape and duct tape to keep the PCA on the universal light holder. that did the trick!
  10. The best thing about Ikelite's iTTL module is the ability to still use manual control of your strobes....just push the buttons next to your left thumb instead of reaching for the manual controllers....getting rid of the manual controllers also lightens and cleans up your rig....plus you can still use iTTL for macro if you want
    Karl
  11. thanks Karl. I am still a dinosaur using ancient strobes! This new technology may actually convince me to get some new strobes!
    Actually I wish there was a strobe available with step less control like the ones I use in my studio! now that would really rule!
  12. The best thing about Ikelite's iTTL module is the ability to still use manual control of your strobes....just push the buttons next to your left thumb instead of reaching for the manual controllers....getting rid of the manual controllers also lightens and cleans up your rig....plus you can still use iTTL for macro if you want
    Exactly!!! Although I use the Canon version - eTTL, it is the same. And very slick!! Just press the buttons to switch to manual and then adjust the power from full down to -3 1/2 stops in 8 increments! No messing with the strobes or manual controllers. It is not stopless but close enough.
    Dave
  13. Stay tuned, Ultralight has something in the works for adding spotting lights to their
    Terry
    Great!
    Lucky me, I just read it before I was in the way to order the long ball mounts and the triple clamps, but since my modeling led light just started to makes problems last night dive I'll wait to see the new solution.
