Monitor recomendation needed.
Started by huguito ·
  1. I have to replace my old Dell 21"
    The monitor shows a heavy yellow tint even after calibration and the contrast and brightness are different from one day to another.
    I run CS2 in a PC.
    I normally calibrate with a Spyder II.
    I want to replace it with a LCD of at least 19" and my budget is $400.
    Any recomendation?
    What are the specs I should look for?
    What contrast ratio is better for image editing?
    HUgo
  2. I believe Dell is having a sale on their 20" Ultrasharp at 35% off so it's around $440. The 19" is going for $300.
    Apply code : 8KRQ6BZ9BRCKBB
  3. I was under the impression LCD monitors did not accurately show colors for calibration for printing.
    Have things improved ?
  4. I was under the impression LCD monitors did not accurately show colors for calibration for printing.
    CRT are generally perceived as giving a better result for image editing, as compared to LCD screens. In this regard LaCie monitors are regarded as the best available, if you can afford them :)
    Also, in the end, any monitor is only as good as its calibration...
    Mat
