D70 and cold
Started by petr ·
D70 and cold
  1. Hi Guys,
    I have problem with the D70 within diving in cold water. The water has 4 degrees and after a shoot the LCD does not want to show the pictures after the shots or it takes to long (40sec even longer sometimes). Out of water the camera works fine. It works fine even in the shallow water where is warmer ......
    Any advice what to do? Do you have an experience like I do?
    Thanks.
    Petr
  2. I have taken the D70 in similar temp water, but never encountered any problems.
    BTW, make sure the lever of the top LCD-light is not on the button while shooting, this gives silmilar results.
  3. BTW, make sure the lever of the top LCD-light is not on the button while shooting, this gives silmilar results.
    Happened to me more then once,
    First time I broke my head trying to understand what the hell is wrong. ;)
    Second time I broke my head trying to understand what the hell is wrong :D
    Third time ...
  4. I have to try it more carefully UW. I have tried to leave the camera outside ( there is 1 deg.) and the camera has worked fine....
    So, the problem is somewhere else.
    I was thinking, that maybe there would be a few levers which clutched the buttons.
    Will see on the next dive......
