c8080 & two housings + bits
Started by early rub up ·
  1. 1 CAMERA COMMING UP TO ITS FIRST BIRTHDAY TWO HOUSINGS WHICH ARE NEW ONE HAS BEEN USED JUST A COUPLE OF TIMES THE OTHER IS IN STILL IN THE BOX 1 SPARE LENS PORT(USED) 1 SPARE LEAD WEIGHT(USED) AND 1 SPARE FLASH DIFUSER(USED) AND 1 SPARE BATTERY(USED) AND THE TTL FLASH CONVERTER(USED)WITH LEAD FROM HOUSING TO FLASH SYNC LEAD
    REASON FOR SELLING I WANT TO UPGRADE AND SPEND EVEN MORE MONEY:rolleyes:
    ASKING PRICE £750 OVNO
    YOU LOT GET FIRST DIBS BEFORE I PUT IT ON EBAY
  2. what is this TTL converter?
  3. what is this TTL converter?
    with a olympus setup you cant use a different make strobe the like sea&sea unless you have a converter its a little cuircit board that goes on the hot shoe of your camera to the housing which enables the camera to speak to the strobe in ttl mode.
    its now all sold
