Ikelite iTTL Compatible Strobes/Sync Cords
Started by dwake ·
  • 26Posts
  • 26Replies
  1. Per the Ikelite web site, in January and February they are going to be coming out with new DS-200 strobes and new sync cords that are apparently iTTL compatible. Per their website:
    "Coming soon are special iTTL sync cords that will allow the newest DS SubStrobe models to provide iTTL compatibility with non-Ikelite housings, and they will be available in single and dual strobe configuraions.
    Coming soon is a digital SubStrobe 200 with a flashy new name like DS-200 in the current gray color. The newest IC chips and IGBT circuitry are allowing this ultra-wide (weitwinkel) and ultra-powerful strobe to move into the digital world. It willl also accommodate an optional EV Manual Controller."
    I called and spoke to Tom at Ikelite and got some mixed messages. He said that the synch cords would only have Ikelite connectors on both ends, which means it will only be available for use with Ikelite housings. So, me with my Subal/D2x combo, am outta luck.
    Now, my wife just got me a new DS125 for Xmas. So, if I read the quote from the Ikelite website correctly, then with the new sync cord, I would get iTTL compatibility with my new flash. But this doesn’t jibe with what Tom told me. I’m confused.
    Has anyone heard anything to clarify this?
    Bottom line is, can I use my new DS125 with one of these new sync cords and get iTTL compatibility/functionality with my Subal/D2x combo?
    Also, assuming I can, would I be able to update my SS200 with the new circuitry to essentially become DS200 and also have iTTL compatibility/functionality?
    Any news/info would be much appreciated.
    Doug
  2. Doug, as far as I know, the only housing that is iTTL compatable is Ikelite, but they don't make a D2X housing....there is an aftermarket TTL converter available also, but I'm not real familiar with it...Matthias TTL converter....a search may get you more information
    Having a DS-125 without a TTL module or converter will not acheive iTTL
    Karl
  3. Hi Karl, Doug is right, Ikelite has been talking about producing an iTTL sync-cord, meaning the iTTL converter will be in the sync cord and can potentially be used with any housing. Check here:
    http://www.ikelite.com/web_two/dsttlplans.html
    They do say that the sync cord will allow iTTL with non-Ikelite housings, but that is only true if they are Nikonos-type sync cords. If they are Ikelite-type sync cords they will only fit Ikelite housings.
    Doug, I think it is possible to put Ikelite connectors (instead of Nikonos) in the Subal housing. What I don't know is if it is possible to retrofit after manufacturing.
    Luiz
    Edited by Rocha
  4. Hi:
    Had two new SS200s pooch on me while diving in Cuba last month. Sent them back to Ikelite for warranty and/or repair work.
    Just recieved them from the factory. The great news is that they now come with a sticker on the inside of the strobe case in the battery compartment that says "Ikelite DS 200 DS Updated". So it won't be long before the new actual model comes out if this is any indication. I will post a photo of the new sticker when I get a chance.
    I too, am interested in the new sync cords so if anybody knows anything, please speak up.
  5. Hi Karl, Doug is right, Ikelite has been talking about producing an iTTL sync-cord, meaning the iTTL converter will be in the sync cord and can potentially be used with any housing. Check here:
    Luiz
    Thanks for the update Luiz.....I read this once but it didn't register that the TTL converter was actually a part of the sync cord....very interesting idea
    Leave it to Ikelite :):)
    Karl
  6. Proves osmosis does not work around here. Tom didn't know we were going to have Nikonos connector on the iTTL sync cords and I didn't know anything about "Ikelite DS-200 Updated" being done. One sync cord concern is correct wiring of the bulkhead in non-Ikelite housings. Competition has offered many variations of what should be. Another alternative is include an Ikelite bulkhead for installation in the housing to assure correct wiring and eliminate the problematic Nikonos bulkhead. We are cogitating............
  7. Hi:
    Here is the picture of the decal/sticker I was talking about in an earlier post about the SS200 - DS200 compatibility upgrade. Hope this doesn't get anybody fired down there in Indiana.
    Ike, If you need further info, feel free to PM me.post-5241-1135616924_thumb.jpg
  8. That's good news Paul, with this (hopefully cheap) update and the possibility of iTTL Nikonos sync-cords I may just want to try TTL underwater again.
    Luiz
  9. James grabs his SS200's and sends them to Ikelite! Since Ikelite sells a lot of Canon housings and has figured out eTTL2, I'm hoping they'll do an eTTL2 converter cord too.
  10. Ike - If I'm reading this right, and (1) I'm using new DS-125s or I get my current SS-200s updated + the new sync cord (which contains the iTTL converter) and (2) my Subal housing is correctly wired via the Nikonos connectors, then I should have iTTL functionality. Correct?
  11. James grabs his SS200's and sends them to Ikelite! Since Ikelite sells a lot of Canon housings and has figured out eTTL2, I'm hoping they'll do an eTTL2 converter cord too
    so would paul, or at least i'd go buy some, if the ettl2 synch cord could have an S6 connector on the housing end B)
    /paul
    Edited by 3@5
  12. Canon requirement of six conductors will be an immediate stumbling block for coversion circuitry in the sync cords. Update of older SubStrobe 200 models requires trashing almost everything except the body, making it an expensive proposition. In other words, iTTL sync cords are more probable than eTTL at the moment. The http://www.ikelite.com/web_two/dsttlplans.html URL describes the why of our strobes and conversion circuitry.
  13. Ike - I didn't get an answer to my previous post. Please let me know if I'm reading you're earlier post right. If (1) I'm using new DS-125s or I get my current SS-200s updated + the new sync cord (which contains the iTTL converter) and (2) my Subal housing is correctly wired via the Nikonos connectors, then I should have iTTL functionality. Correct?
  14. Dwake: Yes. Your assumption is the goal for the iTTL sync cords............
  15. So Ike, if you can't get the D200 to fit in the iTTL housing, we can go to the new iTTL cords and use a manual housing?
    Will we still be able to still use the strobes in manual?....will we have more manual power settings than what's on the strobe?
    Karl
    Edited by kdietz
  16. Canon requirement of six conductors will be an immediate stumbling block for coversion circuitry in the sync cords.
    Beside TTL plans, some inspiration plans ...
    Julian
    Edited by Jolly
  17. We are still cogitating on D200 housing with iTTL and eTTL sync cord for Canon............
  18. We are still cogitating on <snip> eTTL sync cord for Canon............
    <grin> we believe in you, ike :)
  19. Anyone heard any new news on the Ikilite Ittl sync cords? I checked the website and can't find any updates. Last I heard was March-06.
    Ike - What's the latest? Any guess as to what the cost is going to be?
    Doug
  20. Not enough fingers and/or hours in the day for our insignificant little operation to get everything done. We have been distracted by the Nikon D-200 housing and DS-200 SubStrobe for example. We also have to work around some of our people who insist on going diving this week with the new D-200 housing. I told them vacations were illegal and they were bums, but my influence remains zero. Sync cord TTL has not been forgotten...........
