Need Recommendation on Camcorder
Started by Marc Furth ·
  • 11Posts
  • 11Replies
  1. Hi all,
    This is not my regular area for posting but I’m in need of advice. I’ll be making a housing and buying a camera for a present for my favorite dive buddy who is my nephew.
    What I need is a recommendation on a camcorder. My question is their a camcorder made that has a LCD on the back of the camera, not the side. I know of only one I recently seen in a magazine, it was a JVC that used a compact flash card instead of a tape. Does any know this model and would it make a good underwater video camera ? Are their any other camcorders out on the market that have a similar set up with the monitor on the back ? Thanks for any help given,
    Marc
  2. Hi Marc,
    Light and Motion makes a housing called the Mako that has a nice monitor back for most of the PC series Sonys. Its very small and a great travel system
    Light and Motion
    Edited by MikeVeitch
  3. The Everios have pretty poor low light ability and performance. They are super tiny though.
    http://www.camcorderinfo.com/content/JVC-G...rder-Review.htm
    I don't think they have a LANC port so you'll need a housing with manual controls and I don't know of one. I think only Canon and Sony have Lanc ports these days but I'm probably wrong. I had a Canon and won't buy another though they make great still cameras.
    So... my vote is Sony! You can get a generic housing like the Top Dawg and as you've already learned, you'll have to spring for the monitor back on top of the $900 housing for a $1600 total. You can also go Ikelite (my favorite)and get a specific housing where you can see the bulit in monitor.
    Whatever route you go, make sure you have options in place to take it underwater.
    I like the layout of the PC1000 housing http://www.ikelite.com/web_pages/sony_pc1000.html but it is a limited camera though 3 chip.
    If you are going to make a housing, then shoot buy the biggest lens and sensor you can afford.
  4. Thanks for the input,
    I just read several reviews about the JVC GR X5 and one review has it as a
    poor low light performer, and another says it’s very good with the auto gain switch on ?
    It rated as one of the best camcorders in it’s class. I’m not sure what or who I should believe ?
    I like this style of camera because it will fit very nicely in a PVC tube and the monitor will be easily seen on the back.
    As far as buying a new housing it’s out of the question. I've made many housings and I have all the parts I need, I’ll make one for $200. or less.
    Marc
  5. Ahh, sorry, didn't see the part about making the housing....gotcha!
  6. Citizen used to offer a small display that was fitted to some of the early Sony housings.
    Consdidering your expertise at housing items - I would look at a universal monitor as fitted to many car DVD systems.
    Check it out.
    6" HIGH RESOLUTION WIDE SCREEN TFT ACTIVE MATRIX DISPLAY
    RESOLUTION: 1152 X 234 PIXELS
    WIDE ANGLE, OFF-AXIS VISIBILITY
    FRONT PANEL CONTROLS
    ON-SCREEN MENU SYSTEM
    AUDIO/VIDEO INPUT CONTROLS
    NTSC/PAL COMPATIBLE
    WIRELESS REMOTE CONTROL
    http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=14391
    Just an idea !
  7. Thanks for the input,
    Marc
    Post some pics of the housings you've made. Sounds cool.
  8. This is the last housing I made for my Nikon D2X, I've made many others out of different materials.
    Marc
  9. The Citizen Monitor is the M329. There's one on eBay starting at $50 now.
    http://cgi.ebay.com/Citizen-M329-LCD-2-9-C...1QQcmdZViewItem
    It's a little fat since it carries 4 AA batteries, but shouldn't matter to you since you're making your own housing.
    There's also the option of using one of those 2-4" LCD TV's. Some of the Casio models have AV input jacks, model 680 does and there's others. I looked at using one once in a 6" tube housing and it would have fit with 1/2" to spare. Also have their own batteries - and if you're just offshore you can watch TV on the ride back.
    Just curious - what's the port material on your housing? Poly? or Plex? I'd appreciate a link or mfr's part # if possible. And how do you cut it so nicely?
    Edited by sjspeck
  10. Sweet!! Very nice job.
  11. Just curious - what's the port material on your housing? Poly? or Plex? I'd appreciate a link or mfr's part # if possible. And how do you cut it so nicely?
    The end plates are made from 1 inch acrylic. I buy it from different places but you can buy it on EBay.
    I have and use a milling machine with a 10 inch rotary table to cut the circles. Before I bought my lathe and milling machine I used a templet and a router fixed to the bottom of a horizontal table. The router does not have to be mounted to a table but I prefer this over hand holding the router.
    You first determine the circles diameter and copy it to a 3/4 inch piece of plywood. You than carefully cut the circle out using a jigsaw or a bandsaw. Sand the templet smooth by hand or palm sander. Mount this wood templet to your acrylic using double side foam tape, 3M makes a very nice double sided tape that’s about 1/4 inch thick and can be purchased in most hardware stores. Than cut off the excess acrylic very close to the wood templet with your jigsaw or bandsaw. Now you can flush cut the acrylic using a flush cutting router bit or laminate bit. The bearing on the router bit will ride on the wood templet and cut the exact shape as the templet.
    You now have a usable end plate.
    I prefer to sand out the ends and polish them for a finished look. You can start off with 180 and work up to 400 or 600 before you polish the ends on a buffing machine. A buffing machine is the same as a bench grinder that can run at a slower speed, around 1800 to 2400 RPM.. You’ll also need two buffing wheels, one for the compound and one wheel for the final polish with out adding compound to it. If you have never polished acrylic before I would suggest practicing on a scrap piece of material, it's very easy to burn the edges if you apply to much pressure.
    Marc
    Edited by Marc Furth
