CS2 on two computers
Started by ProvoCoz ·
  1. Can someone clarify this PhotoShop CS2 limitation...
    "2.4 Portable or Home Computer Use. The primary user of the Computer on which the Software is installed may install a second copy of the Software for his or her exclusive use on either a portable Computer or a Computer located at his or her home, provided the Software on the portable or home Computer is not used at the same time as the Software on the primary Computer."
    Does this translate to being able to download CS2 to your laptop, in addition to your desktop, so you can use it to work on pictures at remote dive trip destinations?
  2. Seems pretty straightforward. You can install 2 copies of CS2, as long as you dont use them at the same time. So the answer would be, yes you can take a copy of CS2 with you on a divetrip, as long as someone at home isnt using your other copy of CS2 at the same time.
    Cor
  3. Would a crack appear in the universe if you did?
    Would it make a difference if one computer was in the southern hemisphere and the other in the northern?
  4. Hahahahahahahaha :D:o;);)
  5. Would a crack appear in the universe if you did?
    No, but the 2 copies could cancel eachother out!
    You may get interference in the qbit layer if you use them at the same time. (only in the quantum version of CS2).
    Cor
    Edited by cor
  6. Would it make a difference if one computer was in the southern hemisphere and the other in the northern?
    No, but if you use the twirl filter it will rotate different directions!
  7. Is that because the Quantum version is directly tied into the earth's coreolis effect? :)
