How is the ikelite TTL converter supplied?
Started by vannar ·
  1. Is the ike TTL converter supplied with power from the camera? the flash? och with an internal battery?
  2. Is the ike TTL converter supplied with power from the camera? the flash? och with an internal battery?
    Something I can answer... The TTL that is built into the dSLR housing is powered from the 'primary' strobe. When the strobe is powered up the TTL module powers up as well...
    Dave
  3. What he said...
