Looks ok, but has Aquatica corrected a number of minor weak points [apart from the optional viewfinder, which is a very welcome improvement]? for e.g.:
Imp#1: Replace the brand of Nikonos V sockets you use and the wiring in 2x bulkhead configuration. Why not use the Nikonos V sockets that Subal/Subtronics uses, these provide much better and positive contact with no matter what Nikonos cable one uses and they have a lower profile.
The Nik.5 Sockets Aquatica uses are a source of problems and it does not help to have 8 wires going into to primary bulkhead in a 2x bulkhead configuration. I had [and a couple of S2 users that I know] shorts inside the primary bulkhead due to the 8 wires, I had bad contacts with the floatings pins and the cable due to glue that found its way to the spring in manufacturing, I had wire getting rusted at the soldering point inside the bulkhead and breaking off because of a tiny amount of water [not even salt water] made is way in and so on. More often than not on a trip there is an aquatica user with problems with the wiring in the bulkhead.
I was fed-up of these things and just replaced the Aquatica Nikonos Sockets with the brand they use in Subal/Subtronics/Sealux, did the wiring and soldering myself and put shrinkwrap on every wire soldered inside the socket and voila, no bad contacts anymore, no more shorts, no problems. But these sockets use M14 thread which means that I had to remove some material for them to fit in the holes.
Also, why not revise the wiring, instead of having 8 wires going into the primary bulkhead [a recipe for problems sooner or later], get the 3 wires of the secondary to come from the hot-shoe [maybe it doesn't look so fancy but it is less prone to problems].
Imp#2: Make the zoom gear [inside the housing at the end of the zoom shaft] from thougher plastic. When in the rush of things one turns the zoom knob a bit too far the zoom knob [past the end the zoom for e.g.], the gear deforms and the screw that is supposed to keep it in place slides off and voila no zoom/af/mf control for the rest of the dive! Although this is something that can be fixed in secs at the surface, it is ennerving and upsetting how easy it is to lose the zoom UW.
Imp#3: Put alignment marks in the ports, extensions and housing so that user can visually verify that ports and extensions are fully turned [a positive locking thing would be perfect but I guess this is not so easy to do while maintaining compatibility with existing housings and ports]. Although I never experienced a port or extension poping-off in the rib or UW, it does happen often that the port/extension is already half way on its way to disengage. This opens more often with the dome port with cover, especially after a rough ride in the rib. No big problem here, just don't forget to check if they are fully turned before going under but it would be nice to be able to check this just by looking.
