Using EFS 60mm on FF cameras
Started by lanierb ·
  1. I thought people here might be interested to know that you can use the EFS 60mm/2.8 on full frame Canon's via the EF12II extension tube with essentially no vignetting (that I can see anyway). I found this thread on another site:
    http://www.fredmiranda.com/forum/topic/360672/0
    and then tried it myself on my EOS3 (film camera) and it worked great. In air this combination limits you to about two feet max focus distance, but perhaps more underwater? If you put it behind a dome you might even be able to focus to infinity, but that's just a guess. Anyone want to give it a try underwater? (I don't have a housing for my EOS3.)
    Lanier
  2. It works because the extension ring enlarges the image circle, apparently enough in this case to fill the FF sensor. However, it comes at a price. The FF sensor has about 2.5 times more area (1.6x1.6) and blowing up the image with the extension ring will thus cost you about one stop of light. This may not be a problem under favourable conditions but it may become harder to autofocus or to reach a sufficiently high aperture for your DOV needs. Still a nice trick if you already have the lense. A (Kenko) teleconverter may allow you to do the same thing with the same light-loss issue, but without loosing infinity focus.
    Bart
  3. . A (Kenko) teleconverter may allow you to do the same thing with the same light-loss issue, but without loosing infinity focus.
    Bart
    But the teleconverter won't be usable with the EF-S mount of the 60mm lens - or am I missing something here?
  4. Yep, looks like you're right. I thought the Canon didn't work and the Kenko did but it seems neither does.
    Bart
  5. I'd be very interested to hear from anyone who tries the 60 and extender on a FF camera! My suspicion is that although the image circle will be slightly larger because it is being projected further back, it will overall be softer. The 60 Canon macro is I believe an internal focus lens and as such will have been carefully optimised to cover the format its designed for - I haven't looked it up yet but perhaps someone will tell me whether it is designed to work with the tube on the 1.6 cameras? Hopefully I am wrong - this combination would really appeal to me if it works - so if someone tries it and it works well please post.
