I posted a query on robgalbraith.comas to whether this combination is actually viable (to find out if anyone had indeed tried it out and come to some helpful conclusion. To my surprise (and delight) I had the reply below:
Hi Paul:
The EF-S 60mm f/2.8 Macro lens will provide full-frame coverage with some very minor vignetting in the corners of the image on a full-frame EOS camera (digital or 35mm) if it is combined with either an EF 12 II or EF 25 II Extension Tube. The "II" is important, because the original EF extension tubes are not compatible with EF-S lenses.
When the EF-S 60mm f/2.8 Macro is combined with an EF 12 II, the maximum working distance from the front of the lens to the subject is 363mm (14.3 inches) and the reproduction ratio is 1:5. The minimum working distance is 125mm (4.9 inches) and the reproduction ratio is approximately 1.3:1. With the EF 25 II, the maximum working distance from the front of the lens to the subject is 192mm (7.5 inches) and the reproduction ratio is approximately 1:2. The minimum working distance is 117mm (4.6 inches) and the reproduction ratio is approximately 1.6:1.
You won't see the vignetting through the viewfinder on a 5D because of that camera's 96% coverage, but you can see it through a 1Ds or 1Ds Mark II viewfinder because of the 100% VF coverage on those models. In all 3 cases, the vignetting will show up in the extreme corners of the actual images, but it is so limited that it can easily be cropped out if desired.
Chuck Westfall
Director/Media & Customer Relationship
Camera Division/Canon U.S.A., Inc.
