Tetra 5050 help!!!!!
Started by arenny ·
  1. What settings do I have to have on my Oly 5050 to take advantage of the Tetra 5050 ROC/TTL functions? I was using "external" flash only to conserve battery power. After reading some posts it seems like you need the "internal + external" to be able to have the ROC work, or is it "slave" setting? I guess that if I have the setting to "external" only, I am using the Tetra as a manual setting, adjusting the output myself. Should the flash be in "slow 1"?
    I also heard that the constant flash inside the housing makes it too warm. Can you set the flash at -0.7 EV or something to conserve power? How can you switch from manual to ROC quickly? I also heard that you should turn your infra red illuminator off.
    Thanks!!!!!!!!!
  2. Search the forum for "oly settings" you´ll find everything you need.
  3. I might be doing something wrong because I have searched everywhere that had "Tetra" and Oly settings, couldn't find these specifics.
  4. On the back of the Tetra housing are 3 buttons for the ROC system. The one on the right is "ROC on/manual mode". There should be a indicator light above the LCD window when ROC is on. (It's been awhile since I've used my Tetra but think I have this correct.) When you are in "manual" (just push the button - no indicator light) just use the other 2 buttons (+ & -) to change strobe output. The column of LEDs on the left side of the LCD tells you where the strobe power is set. Strobes are always on TTL as I recall. You shouldn't have to touch the strobes at all. The onboard strobe does need to fire (internal + external). (I use S&S YS90DX strobes.) Had condensation issues a few times when rapidly taking lots of pics. Putting a few silica gel packs inside the housing should prevent this.
    Edited by jcclink
  5. Thanks!!!
