Flash arms and Hugyfots...
Started by davichin ·
  1. I am trying to choose a couple of new arm systems for a new Hugyfot housing. As far as I have tried and seen I want some rubber in the tightenning clamps (I actually own an arm system that is either too tight or the strobe is dancing around). Does anyone know if Hugy´s handle ball is compatible with ULCS even if it doesn´t have o-ring? Does ULCS have an special piece to substitute Hugy´s ball?Could you give me an advice on different arm systems or if is there any previous topic where to read about different arm systems? :P
    Thanks in advance!!
  2. Yes - ULCS go straight onto Hugy balls!
  3. Hola david,
    yes, my current setup is a Hugy housing with ULS arms and clamps.... And it works very well.
    Matetes
  4. FYI
    Many manufacturers have now standardised on 25mm/1inch (they DO interchange pretty well) ball joints.
    Those that I know produce balls of this size are:
    Seacam, TLC (Aquatica), Ultralight, Ikelite (1"), Inon, obviously Hugyphot (as stated in this post), and probably more.
    At last an underwater standard of one component at least!!!
  5. At last an underwater standard of one component at least!!!
    Similar to Nikon eh Fanboy?
    :P
  6. I remember Nikons..........
