Sea & Sea iTTL converter
Started by jarhed ·
  1. I'm in the process of researching a housing system for my new D200, I have pretty much settled on the Subal housing, and because I'm new to this, I would like the option of having TTL avialable, especially for macro work.
    I own a YS-90DX and understand that I would need to buy different strobes to use the HeinrichsWeikamp converter.
    From Sea & Sea's website, it looks like they make a converter that should work:
    http://www.seaandsea.jp/products/digital/dxd200/acce.html
    Does anyone use this and if so, offer any recomendations?
    Many thanks,
    John
  2. from my understanding, I hear the S&S converter is actually an OEM Henrich circuit. Anyways, I plan on getting the S&S converter later this month when I order my S&S housing
  3. I like the looks of the Sea and Sea converter - it's external and it looks like it can be used w/ any housing that uses Nikonos bulkheads.
    If it does use the base processor from the Heinrich's unit, I wouldn't be surprised - however, it has some external interface added, like the manual to ttl switch, and the flash compensation.
  4. It also looks to be campatable with alot more strobes than the Henrich circuit; mostly S&S strobes, but they are popular.
    Appreciate the comments.
    John
  5. According to Sea & Sea, the TTL convertor plugs into a 6-pin bulkhead on the housing, but you plug 5-pin Nikonos-style strobe cords into the convertor, so it may require a retrofit to your housing.
  6. According to Sea & Sea, the TTL convertor plugs into a 6-pin bulkhead on the housing, but you plug 5-pin Nikonos-style strobe cords into the convertor, so it may require a retrofit to your housing.
    Yes this is true if your a cannon shooter, but as I have understood it. The Nikon iTTL protocol uses only 5-pin.
    But you may still have to rewire the cables between the nikonos connector and the camera to connect al the 5 pins directly to the camera.
