Teleconverters
Started by famorim ·
Teleconverters
  1. Hi folks,
    I got an opportunity to get in hands both, kenko and Tamron, teleconverters this week. I did some tests with appertures f/8, f/11 and f/16 (will post later).
    Both TCs working very well with Canon EF 100mm f/2.8 Macro, AF worked, but AF don't work with non f/2.8 lenses. I did tests with:
    Canon 100mm f/2.8 Macro - AF works
    Canon 50mm f/2.5 Macro - AF works
    Canon 70-200mm f/4L - Manual
    Canon 17-40mm f/4L - Manual
    Canon 15mm f/2.8 Fisheye - AF works
    Canon 24mm f/2.8L - AF works
    Sigma 15mm f/2.8 Fisheye - AF works
    here is the link http://www.pbase.com/famorim/test_tc
    Regards
    Fabio Amorim
  2. Hi Fabio - thanks for the test.
    Very hard to tell on the web, but did you rate the Kenko higher?
  3. Hi Anthony,
    It's very hard to tell who is better. The construction is pretty good, the soft case, caps and body are pretty similar. Both looks like was made from just one manufacturer.
    If you want I could make you available the high resolution file to analysis.
    Regards.
  4. Thanks Fabio,
    I was just interested in what your assessment of the original files was. At this stage I don't need a TC. :D
  5.   It's very hard to tell who is better. The construction is pretty good, the soft case, caps and body are pretty similar. Both looks like was made from just one manufacturer.
    Funny that. They are actually the same, just branded differently. :D
