Flood threat with a Subal Dome Port ?
Started by garoupa ·
  • 27Posts
  • 27Replies
  1. Last Dec on a trip, a friend's broke. We applied duct tape and all was OK for the trip. It was replaced free of charge. I purchased 2 Subal domes in February and they were thicker and of a more flexible, rubber material. I believe Subal was previously making them from a more rigid material that was prone to breaking. See your dealer for a replacement!
  2. Both my FE2 Subal domes have been fine. I think that the early Subal domes were fine - there was then a batch that caused all these problems - and they are now OK again.
  3. On the question of flooding, when I showed the loose O-rings on my ports to the guys at Subal, they told me they were not Subal factory-supplied O-rings! So, goodbye blue O-rings, hello tighter factory-supplied black ones!
    Edited by John Bantin
  4. Blue o-rings on a Subal? Sounds like those self lubricating Sea and Sea O-rings. The FE2 dome uses the thicker o-rings. If somewheres 3rd party o-rings were substituted they may have been the wrong thickness.
    Knock on wood but my dome shade has been fine. It has taken quite a beating also. It was one one of the early ones I believe.
    Edited by davephdv
  5. Glad to see this thread. Just found that my sunshade is broken this morning :ninja:
    Last time I used it was last August and it has been sitting in my stormcase all these times. I went diving in January but did not use it. Of course now as I am packing for my Palau trip (leaving this afternoon), I found the problem. Oh well.. at least I have time to run out and get some duct tape :rolleyes:
    Also my wet alarm sensor battery is dead! Now I am very paranoid, not a good way to start a trip, I am afraid ;)
  6. Blue o-rings on a Subal? Sounds like those self lubricating Sea and Sea O-rings. The FE2 dome uses the thicker o-rings. If somewheres 3rd party o-rings were substituted they may have been the wrong thickness.
    They were the right thickness but slightly too long. They were supplied by the local distributor. I'm still waiting for the replacement lenshade (about a year) and long after I moved to a different brand of housing! The local distributor is a lovely guy. He's so relaxed he's horizontal. Alas, I was not so relaxed.
  7. Here are two that self destructed on the same dive on Saturday
