WP-DC90 wide angle lens adapter
Started by auder ·
  1. Hi all,
    The problem is the vignette :)
    Check the link:
    DIY
    Best regards,
    Auder Machado Vieira Lisboa
    UW amateur photographer from Brazil
  2. Ikelite housings work with wide angle lenses.
    I think the problem is also due to the Sea & Sea lens. The rear element diameter is probably too small. Looks like you're using a bayonet mount lens. If you used their 16mm lens (originally for Nikonos), you might have better luck.
  3. Ikelite housings work with wide angle lenses.
    The Ikelite housing will vignette similarly, this limitation is imposed by the lens of the camera.
