16x9 Hi Res Monitor
Started by Nick Hope ·
  • 56Posts
  • 56Replies
16x9 Hi Res Monitor
  1. Anyone have any news on future availability of hi-res 16:9 externally housed monitors? Seems a lot of people are still getting 4:3 low-res options to use with HDV which is far from ideal.
    Last I heard, Amphibico were working on one. What are the specs? Who else is working on one? What size? What resolution? When?
  2. Nick by the time you get your HDV rig you are going to know exact what to get by all us beta testers here..
    Yes the Canadians are working on a small affordable 2.5 inch wide 16.9 Hi Res external LCD. I'll see it I can get any sneak info......but it should be ready by the end of the year.
  3. True Wags, you'd think I ought to but I'll probably still screw up and get the wrong gear :blink: All your beta testing and feedback is highly appreciated! At least I've committed to the camera now (Z1).
  4. Nick, No question about it, the Z1 is excellent but you may want to see how the FX-7 fares before purchasing. Never the less, one thing I've learned since going to HDV is that if you are going to be using a monitor, a hi rez one is imperative. Focus is too important and the visual between current monitors and the actual viewfinder is quite large.
    Steve B)
    Edited by steve
  5. I would agree with Steve. Current monitors are useful for framing only with these hdv cams. For accurate color and focus info, you need the native monitor. When they build an hd ext monitor, they better connect it to the component out jack (won't do much good going through the constrained analog RCA). Even with my hi res native monitor, things can look crisp that are infact pretty fuzzy. You need all the advantage you can get.
    For this reason i use my native montior almost exclusively now. So, L&M and Amphibico users are very fortunate to have this top window to view it. It certainly changes your shooting style, but once you get used to it, it is not much of a handicap (different does not equal less effective).
    -Shawn
  6. Will the FX7 offer variables between PAL and NTSC? If not I would hedge bets on the Z1. The ability to switch to the client requirements is a massive bonus to any International shooter. Makes sense too not to have to worry about getting two cams.
    I was looking at the Marshall 7" external field monitor but we all know the story there to house it. A lot of people using the HVX200 when it first came out were opting for the Marshall as potentially the best option for external monitoring of their shoots.
    The specs of the monitor can be found here. Its not a true native HD option but the best available until about 6 months ago. I've not kept up with external monitors since then so there could be something better out there now.
    Mark.
  7. Mark,
    Have you heard anything more about the monitor yet? I would be very interested in the pragmatic results.
    Steve B)
  8. Hello everybdy,
    FYI, I just talked to the L& Motion guys (tech support), and I understand that it'll be a while before they come out with a true 16:9 top monitor. And hopefully they'll hook it up to the component out jack of the cam, as pointed out by Shawn.
    Mark, neither the FX7 nor the pro version, the HVR-V1, will offer NTSC / PAL switchability. The Z1U is the only one so far. That's why I'm leaning towards the Z1U at this time.
    Mark, I remember when I was there working with you in Palau, that there was this italian guy who was shooting with a PD100 in widescreen, and was using this big 16:9 monitor that was about 18" by 10" or so (external measurements from memory, NOT actual size).
    The monitor had shades on the two sides and the top.
    The guy told me it was made by an italian company, can't remember the name.
    I do NOT think it's the company by Jean Claude Uldry (http://www.adval.it ), at least not based on what I see on their website.
    Anyway, I remember he was pretty happy with it, although it is a big/bulky monitor, and for sure it'll make for some huffin' & puffin' when shooting in strong current, etc.
    Of course, it is not clear whether that monitor was a regular "squished" SDefinition monitor, or "HD-ready", and therefore able to display more detail than a regular SD monitor (important for HD focus).
    If anybody is interested I can try to track him down through some uw video/photo connections I still have in Italy, and see what I get.
    My .05
    Nick
  9. You may have a look at extreme vision a french company, they have a 7" 16:9 HD monitor at a reasonable price (1520 Euro)
    I have seen it working on a Z1 and it looked fine (good contrast, bright screen)
    If you want to have a look go to: www.extrem-vision.com
  10. Here's a photo of it
  11. Hey redryder,
    thanks for the info on the trem-vision.com.
    Went there, looks like the english page is not enabled. From the french version of the page, it's not clear what the rez on that monitor is...
    It looks like the monitor's power autonomy is only 90min, but at least it is PAL/NTSC switchable...
    It also looks like they're working on a housing for the FX7...
    Nick
  12. Wow those are abit $$$
    I did hear that the Amphibico one is going to be like 16.9 / 4.3 and have true full digital 24 bits...so nice and sharp. Not sure how much though.
  13. Trust in the economy and demand....it will be a lot of money...but folk will buy it because a SD monitor just doesn't do it when shooting in HDV...unfortunately.
    Steve B)
  14. Hey redryder,
    Nick
    they will be in antibes, if you prod me just before the dates i will try and remember to ask them :)
    (antibes in 25-29oct)
    /paul
  15. It was hinted to me early on this year that the Amphibico HDV monitor was going to be around £1300...
    But once again that was just rumours..Although from a quite reliable source.
    But as need rises, so does the price.
    If L&M come out with a decent one that fits the Amphibico range then we can look at that. Although they tend to be more expensive when first released, Other wise I'm buying a 14 inch HD ready LCD and sticking it in a tupperware box. :)
    Dive safe
    DeanB
  16. I hope it want be that much $1300 pounds is like over $3000 AUS. $1500AUS and they would sell like hotcakes I recond.
    Buying an aftermarket one and making a box for it might not be a bad idea after all.
  17. Amphibico is trying to use the Sony display used in Sony PSP hand held videogames......
  18. Just got off the phone after a semi heated dicussion with my Amphibico dealer concerning 'why' my housing is 'yet to be looked at' even though I sent it in last thursday on the assurence it would be hopefully ready for my shoot this thursday..O.k if they couldn't get the parts at least I could have hired one in time.. ;)
    When midway through his explanation about being 'holed up' with the chairman of Amphibico all week, he mentioned the arrival (late Jan to Feb 07) of the 16:9 HD Monitor.
    Here's how it went.
    They (Amphibico) are hoping to have the monitor ready by Jan or Feb next year, but its going to be expensive.."How much do you call expensive" Well, it will be around the £2000-£2500 mark... But it will be worth the wait. Peter Scoones has ordered Six already...
    Well fair play to old Scoonsey..He's got the BBC platinum card.
    (Why do people think if they load you up with 'big' names you'd be dumbfounded into believing anything.)
    Who are Amphibico aiming their market at for christ sake..The Sultan of Brunei.
    I am seriously heading towards Gates I tell you. Although my man At Amphibico tried to tell me all the 'Big players' used Amphibico. Well I know for a fact Doug Allan uses Gates for his Z1 because he was going to sell me one of them With the Monster Fathom lens. Should have excepted the offer and Peter Scoones makes his own housings for the HDCAM which he supplies the BBC, he told me himself.
    Anyway there it is...
    Dive safe
    Dean(kit less)B
    Edited by DeanB
  19. Go Dean.....
    $2000 pounds...thats like $5000 AUD? I hope they don't end up costing that much. We really might have to start making our own.
    Wonder how much a FX1 LCD costs to buy. Just have to house it and run the wires into the housing.
    We had some guys here once shooting with a Digital Beta and the housing was made by a local Perth engenieering company, they paid like $8000 AUS for it but there they were under the water filming with it.
    Edited by wagsy
  20. Yeah, I love a rant..
    Especially a deserved one. I'm sat at home on a lovely day with no camera to play with. ;)
    Should be at my topside location shooting kingfishers, watervoles, coots etc, etc...
    Thats another thing the service guy asked me to send my camera inside the housing so he could check 'Compatability' Then the main boss man says "we have plenty of A1's here so there was no need". Apparently though he's having lunch with Posh n Becks and Kofi anan :glare:
    "Whatever girlfriend"
    They can take my housing but they will never take my camera..Oh shit, they already did. :P
    Dive safe
    Dean(THE RANT)B
