Most useful controlles?
Started by krija044 ·
  • 10Posts
  • 10Replies
  1. Hi all,
    I've earlier designed a housing for an older semi-SLR camera (Olympus C-5060WZ). I would now like to design a housing for a DSLR. Which one I don't know yet. What would like is to get some overall advice from you who already have DSLR housings.
    Which controlles are the most important and needed for a DSLR housing?
    Most commercial housing have all controlles but I don't think that is necessary, or?
    Thanks in advance!
  2. I probably use my camera less times than some in here ... and .. am less technical than most .. yet I think I have used every button on my camera underwater, I would even like to add a few like .. a switch for the manual or auto focus switch on lenses !!!!!
    I am a canon user .. and there aren't many button you would find never using .. but I am sure if you wanted to you could "do without" a couple .. mostly on the top for the shot type .. but why miss it when ther eis a WB button there ?
    My opinion is cover all of them if you can.
  3. Hi Krija,
    It would probably help if we knew which DSLR you were tending towards. If not a particular body, at least a brand. Each brand tends to have a different logic to their control layouts that heavily influences which buttons are most useful.
    Martyn
  4. I'll break this down for the Nikon D200
    Essential - can't do without
    Shutter release
    Almost Essential - cant function effectively without
    Main comand dial
    Sub command dial
    Playback
    Delete
    Multi Selector
    Power switch
    Focus mode seletor
    Very useful
    Mode
    ISO
    AF area selector
    Exposure Compensation
    Flash compensation - only if you had a ttl strobe
    AF-on
    Buttons I have never used underwater
    WB
    Qual
    Menu
    Thumbnail
    Protect
    Enter
    BKT
    Metering selector
    AE/AF lock
  5. I'll break this down for the Nikon D200
    Shutter release
    Main comand dial
    Sub command dial
    Playback
    Delete
    Multi Selector
    Power switch
    Focus mode seletor
    Very useful
    Mode
    ISO
    AF area selector
    AF-on
    WB
    Qual
    Menu
    Thumbnail
    Protect
    Enter
    BKT
    Metering selector
    AE/AF lock
    Using Lionfish list I would say:
    Shutter release
    Main comand dial
    Sub command dial
    Playback
    Delete (with a big enough card I wouldn´t need to use it)
    Multi Selector
    Power switch (If you remind to turn it on before diving is not that necessary)
    Focus mode seletor or AF LOCK (I think I could live without focus mode selector)
    Zoom knob if you want to use zoom lenses ( this is a complicated thing)
    Very useful
    Mode (I always shoot Manual)
    ISO
    AF area selector
    Exposure Compensation (only if you don´t shoot manual)
    AF-on (I don´t have nor I miss it)
    WB
    Qual
    Menu ( this and Enter could give some options like ISO,QUAL,WB...)
    Thumbnail
    Protect
    Enter
    BKT
    Metering selector
    AE/AF lock
  6. Using Lionfish list I would say:
    Shutter release
    Main comand dial
    Sub command dial
    Playback
    Multi Selector
    Very useful
    ISO
    AF area selector
    WB
    Qual
    Thumbnail
    Protect
    Enter
    BKT
    Metering selector
    AE/AF lock
    Just a little clarification
    I really use the power switch to turn the LCD illuminator on
    The focus mode selector isn't he same as the AF Lock. It's the button on the front that's sometimes refered to as the MSC switch. I do switch between Manual, Single-servo, and Continuos.
    But I agree that both of these buttons are grey area and could be moved to the Useful category
  7. I agree except that:
    Power switch is necessary. Even though you might turn it on prior to the dive I have had camera hangups occasionally (more often with TTL) that required cycling the power on the camera. This is pretty nice to have.
    WB is essential. If you want to use filters (and they are amazing) then it is best if you can pre-set your WB.
  8. The best advice .. is to buy the camera .. use the camera ... and get used to the controls ... and thendecide for yourself which ones you think are essential.
    I still say that if you don't put the button in you will probably find a use for it underwater sometime.
  9. Thanks alot for your answers! Sorry for my late reply but I thought I checked the e-mail notifaction box and when I didn't recieve any mail I assumed there were no answers.
    Hmm... maybe you're right Giles about the use of all controlles. But I also think that Lionfish43 (and the others with useful comments) have presented the useful controlles in a easy way. I will check into that. It would save time not have to make all of them...
    And you're right, it will be a lot easier when I know what camera to buy.
  10. Giles is on to it. Make sure the controls that suit your shooting style are available. For the critical ones, remember that their placement is important.
    When shooting available light (which I do in aperture priority auto) I like to be able to compose, zoom, select aperture and exposure compensate without taking my eye from the viewfinder, so for me having those controls within reach is critical.
    About 4 posts into this thread is a pic of placement that is working for me.
    http://wetpixel.com/forums/index.php?showt...418&hl=d200
    But if you shoot some other way, adapt the positioning to suit where possible.
