Got my Sea&Sea DX350 - Problems with 1st dive
Started by Nunomix ·
  • 22Posts
  • 22Replies
  1. if the BCD was a little smaller, maybe one on each side of arms would be more streamlined/ convenient. The way nunomix has it setup, I can see myself getting annoyed moving from viewfinder to above the camera while trying to compose a macro shot.
  2. I finally went down with my S&S housing with TTL working. Got the camera back from S&S Netherlands and apparently the TTL is working fine. Well... I still have a problem... The TTL converter does not work properly in position "-1".
    I also tried the Patima BC that Sam (Shchae) kindly offered to me. I tried it with my macro setup and it feels much better than in my first test without any "floating add-ons". Now I was able to dive normally with the housing without feeling I was being dragged down to the core of the Earth :). The TTL converter makes the camera roll to left side unfortunately.
    Near the surface (until around 2-3 meters) the Patima BC (together with a ring I made to put around the port) is positively buoyant and it becomes negative below that depth. Nevetheless, the difference between using the BC and not using it is massive. Much better with it.
