Expodisc White Balance Filter
Started by videodan ·
  • 164Posts
  • 164Replies
  1. I found the tests very informative, and really appreciate your work to do them and post the results. A great learning experience.
  2. I thought I'd report back on my totally non-scientific tests with the Expodisc and my EVO housing.
    As mentioned previously, my idea was to buy an Expodisc and then power-up my EVO/HC1 with it in place since I don't have MWB control with my housing.
    So a couple weeks ago in Curacao that's what I did.
    Unfortunately, the results for me were indifferent at best. I tried several tests while pointing at both white sand and the sun from around 60' during the startup process but I really can't say that I saw much of a difference.
    There is a slightly more neutral tone to the footage shot doing this process vs. just starting up the camera without the Expodisc in place but it's more of a cooler, slightly greyer tone than anything else. The colors didn't seem to be much better in either sample. Based on previous results posted by others here I expected warmer, more lifelike tones using the Expodisc.
    I suppose it's also possible that the whole process of starting up the camera in this fashion has some flaw I've not considered that precludes this idea from working.
    And I only tried it one day, under semi-bright conditions, so there might be other situations where it would've worked better. The one day we had really bright skies, I left the filter in my apt...
    Bottom line:
    I have an 82MM Expodisc for sale in the classifieds.
    Edited by sjspeck
  3. Can Amphibico add the MWB control option to your housing ?
  4. Can Amphibico add the MWB control option to your housing ?
    Their solution is a mechanical button to press the assignable button on the A1U. But I have an HC1 - it doesn't have an assign button.
    I knew that when I bought the EVO though. It wasn't until almost a year later that I decided to play around with MWB.
    For what I normally shoot - clear Caribbean water, less than 90' - I'm finding that my HC1 does a nice job of Auto WB. And I can fix it in post....
    I just saw a video posted by someone on another forum, their contention was that although they could "fix" the blue, they left it in since that was what they perceived while shooting. I think I'm starting to agree...
    Edited by sjspeck
