Canon EOS-1D Mark III announced
Started by herbko ·
  • 74Posts
  • 74Replies
  1. looking at the table above, say you expose the sun area correctly (exposure zone 1) and want to bring detail back to an area that was 4 stops underexposed. With the 12bit images you will have 256 levels available, with the 14bit image you will have 1024. The 14bit image will look better after post-processing, right?
    Dirty data, whether it's the result of sensor blooming on the high end or underexposing on the low end remains the same. 14-bit processing just places a greater scrutiny (levels/gradation) on it. This is analogous to what happened when we used 10, 12 and 16 mp cameras with lenses designed when 4, 6 and 8 mp cameras were the hi-end. Suddenly what we once couldn't see now came into a sharp focus, and some of it we didn't like much. It changed how we shot and changed what lens we shot with. Example: 12-24mm nik behind a dome.
    14-bit.......essentially, in the case of sunballs, it will heighten the evidence of fringing on the high end as well as the evidence of noise on the low end. Plus it will preclude using underexposure as a workaround for the same two issues.
    Better processing will require cleaner capture data if the proportional distributions remain the same (Canon has not indicated they have changed). Sunballs or the popular workarounds when shooting sunballs do not deliver cleaner data. I cannot see how greater scrutiny on dirty data makes the image better. I can see how 14-bit and higher processing will make us shoot in a way that minimizes what we now consider acceptable. I can also see why it is better. I just don't believe it will make certain shoots improve without first being captured on a sensor with higher dr. Sunballs is one of those image types.
    I won't bore anyone with further comments on this subject ;)
  2. Most of the lenses we've been using were designed for film cameras. I don't see what the lens resolution and distortions have to do with the discussion on dynamic range and sunballs.
    Better dynamic range than what? Have you used a Canon 5D? As I mentioned earlier, I think the 5D images are limited by the 12-bit A/D. It would look better with more quantization levels at the dark end. Canon claims to have preserved that with the reduction in the size of the photosites. Of course this claim can't be verified until the cameras are out.
    Edited by herbko
  3. As I mention early, I think the 5D images are limited by the 12-bit A/D. It would look better with more quantization levels at the dark end. Canon claims to have preserved that with the reduction in the size of the photosites. Of course this claim can't be verified until the cameras are out.
    If you check the photographic test results at 5D Dpreview you find that the noise levels bottom out at 1 bit level for low ISO. This strongly suggests that you are correct. For low ISO images, the camera is limited by the 12-bit ADC. Assuming that the 1DMarkIII is similar, it will benefit by the 14-bit ADC.
    That being said, my 5D shows patterned noise in the shadows that its certainly not random. I don't know if I just got a bad copy, but I have seen other comments to this effect on various forums. My guess is that it is probably due to some sort of pickup on the video amplifiers. It shows up as rows and columns that are lighter or darker than their neighbors. I think I am going to borrow a friend's 5D to do some comparative tests.
  4. Most of the lenses we've been using were designed for film cameras. I don't see what the lens resolution and distortions have to do with the discussion on dynamic range and sunballs.
  5. Any vendors going to build a housing?
  6. Did you notice the AF button on the camera back? post-630-1172562217_thumb.jpg
    The button to the right of the viewfinder is AF-on, This will achieve the same functuality as Custom Function 4-1, that is, removing AF from shutter release and applyng separately to that button. Very useful for many applications, not the least of which is shoooting the 100mm macro with combination of AF and MF or locking WA focus on a particular part of the frame without need of compose/shift.
    Before MKIII it took several steps (buttons and dials) and reading small menu items to make the shift to CF-4-1. Now it is a single click from a dedicated button.
  7. Where's the PRINT button? ;)
    Edited by herbko
  8. And they've not included an auto-composition feature either.....
  9. Hi guys,
    I have seen a lot of the information and tech specs online in the recent months. So some of the discussions above are nothing new to me. But to say that I was eagerly waiting for the Mark III release is an understatement... Like Pavlovs Dog I am drooling puddles big enough to dive in to get my hands on it and get it underwater. Any improvements on a Pro Camera will have some chasing that extra edge in producing an image that captures your imagination and to ask yourself... How did he/She do that!. Now if I can only buy one :D
    Cheers!
    Terry Moore
    www.liquidmotionproductions.com
  10. The lens does look interesting. Disappointing that it's designed with an 82mm filter thread. That means a new set of filters ...
    I am still waiting on my Heliopan circular polarizer for this lens.
    Just picked up a Heliopan UV filter but had to wait almost three weeks for it.
    Now on my 5th week for the polarizer....
    I'm in India and hope to test drive the lens topside tomorrow.
    BTW, zoom gears are all new too and the lens is so seriously back-ordered some manufacturers can't even get hold of one to measure. I made a DIY gear in the meantime.
  11. I got to try out the 1DmkIII the other day. It's a big improvement in ergonomics over the MkII. When I switched from Nikon this was one of my biggest gripes - why do I have to hold down two buttons and turn a dial to change the ISO? Now there is a single ISO button and you can press and release it, then change the dial. Yeah! Many of the other buttons are press and release now.
    Also, the MkIII also has a small joystick controller now. You can't use it underwater (and don't need to) but it's probably nice for above water use.
    The weight is considerably less and the big LCD is a dream.
  12. I have a mkIII and am currently in Alaska photographing humpback whales- above water only. This new camera is indeed a great improvement in ergonomics, as James stated. I've owned all 1 series digitals since the beginning and it is the easiest, fastest, to handle. No more "button gymnastics". Thank goodness.
    Amazingly fast motor drive, of course. Image quality looks pretty good so far. I don't know if I agree with some of the web gurus stating that "on a pixel by pixel basis it's the finest DSLR ever" but time will tell. It's a totally different machine than the 1ds mk2, so IMO impossible to compare. I just wish this thing had more pixels.
    One gripe- very, very hard to read the histogram (meaning difficult to determine where the boundaries are), because the background color is very dark, just like the background of the LCD... So it's a pain to know how close to the edges your data is...
    brandon cole
    Edited by brandoncole
  13. Subal has confirmed they are housing this, and there is something on Nexus' Japanese site about a housing too.
  14. Subal has confirmed they are housing this, and there is something on Nexus' Japanese site about a housing too.
    Seacam too, of course. Hopefully by DEMA, as Harald has already begun work on the housing, but no confirmations on delivery schedule from Austria yet.
    Edited by StephenFrink
  15. This 1.3x camera does not have a 180º fisheye, does it?
  16. Anyone confirmed the focusing glitches reported on Rob Galbraith ?
  17. Still praying and waiting for the 5D replacement. Hoping my wait is rewarded by some of these features making their way into it, like the 14 bit.
    I like the 5D price tag better unless I can justify to the wife I will sell more images with the new camera. :)
    Todd
  18. The focusing problem affects AI-Servo shooting. Not something I use a lot underwater. I do use it sometimes though.
  19. Appears Canon is addressing the focus issue....at least the AI Servo issue.
    Letter that Canon Service Center is apparantly including with returns. Found this on a website:
    Some Canon 1D Mark III owners are reporting that Canon Service Centers are installing firmware v1.0.9 on their DSLRs. Following is the text of the letter that is suposedly returned with the updated cameras ...
    _________________________________________________________
    EOS-1D Mark III Firmware Update, Version 1.0.9
    Dear Canon Customer;
    We have updated the firmware in your camera to the latest version (Version 1.0.9). This firmware update incorporates the following improvements and fixes:
    1. Improves the look of images when enlarged on the LCD monitor. Applies a slightly stronger sharpness setting to the LCD monitor when images are enlarged.
    2. Counter measures for Main Dial response errors (Main, Quick Control, Vertical-grip Main). Fixes a rare response error in the Main Dials in which they either did not respond when rotated or would change several clicks' worth even if only clicked once.
    3. Improves the consistency of AI Servo AF under certain conditions. Reduces the tendency of the camera to autofocus on high-contrast backgrounds when shooting in conditions where AF detection is difficult, such as when the main subject is not completely covered by the AF frames or if the main subject's contrast is low.
    4. Corrects errors in the Italian and Simplified Chinese menu screens.
    Please note that this Version 1.0.9 firmware will be made available for download from the Web at the end of July. However you will not need to take any action as your camera has already been updated.
    Thank you for your understanding.
    Edited by dmoss
  20. Rob Galbraith does not believe that the firmware 1.0.9 fixes the autofocus problem :-(
