Nice! What's that advantage to attaching on with a PC cable as opposed to just using a dual sync cord?
I don't own a dual sync cord so I wouldn't be able to answer what if any advantages there would be over a pc to Ikelite sync cord. However I do know that with a sync cord that has a PC connector on one end and and Ikelite connector on the other end you do not need to use an underwater housing..............please correct me if I'm wrong, but I believe you might have to use a housing if using a dual sync cord that had all Ikelite connectors. Also, by triggering the slave strobe optically as opposed to using a dual sync cord reduces the amount of cords by one........and one less cord in a photo studio is one less cord to accidentally trip over.
Also, my PC to Ikelite cord is 10 feet long. When using a 100mm topside for product photography, distance from camera to strobe and subject may become an issue relative to sync cord length.......but that said, not as much as when using a 17-55mm as I did for the image above (focal length at 55mm).
My post is not meant to contradict what Marc and James have suggested, but to support the information that was conveyed to grunzster. Please note Marc and James' unfortunate circumstances were with the substrobe 400 whereas I am using a pair of DS 125 substrobes. Also, since I still consider myself a student of product photography, I take my time and assess each image prior to capturing the next shot. Shoot, review, adjust, shoot again...........not usually for the benefit of exposure but more for the problems that exist with a high glare surface (iow, trying to minimize the blowouts)........iow, there is a built in lag time between images while I reposition the strobes or foam core in an attempt to knock down the glare (Matt, I'm still planning on trying that polarizer you recommended
). And as I also mentioned previously, my strobes are set usually at 1/2 power.
hth,
b
