Canon News
Started by dragan ·
  • 22Posts
  • 22Replies
Canon News
  1. 1Ds Mark III
    Release date: Dec 10
    Price: $7999
    From Amazon
    Product Features
    21.1-megapixel full-frame CMOS sensor
    Large 3.0-inch LCD display with Live View and seven brightness settings
    5 fps at shutter speeds 1/500 second or faster (for bursts of up to 45 Large/Fine JPEGs or 15 RAW images)
    sRAW mode; 35-zone metering system; 45-point AF; integrated Self-Cleaning Sensor Unit
    Powered by LP-E4 lithium-ion battery pack; stores images on CF, SD, or some SDHC memory cards
    Technical Details
    Effective resolution: Approximately 21.1 million pixels (total pixels: approximately 21.9 million)
    Recording pixels: 5616 x 3744
    Sensor type: Full-frame CMOS sensor, with primary R-G-B filtration (28 x 18.7 millimeters)
    Pixel size: 6.4 microns square
    Lens focal length factor: None (1x)
    Imaging processor: Dual DIGIC III image processors
    Maximum frames per second: 5 frames per second (fps) at shutter speeds 1/500 second or faster, in all recording modes
    Drive modes: Single; silent (single-frame); high-speed continuous (5 fps; adjustable 5 to 2 fps); low-speed continuous (3 fps; adjustable 4 to 1 fps)
    Maximum number of frames / burst: JPEG: 45 (full-resolution, Level-8 fine compression); RAW: 15; RAW plus JPEG: TBA
    Flash sync speed: Up to 1/250, with EX-series Speedlites
    Shutter "lag" time: Approximately 55 milliseconds (from half-way to fully depressing shutter button)
    Start-up time: 0.15 seconds
    Image type: JPEG, RAW (14 bit); improved A/D conversion to 14-bit processing for 16,384 individual tones
    Highlight tone priority: Improve tonal range in highlight areas by approximately 1 stop (C.Fn II-2)
    Noise reduction: Long exposures 1 second and longer (C.Fn II-1); high-speed ISO images (C.Fn II-2)
    Storage media: Compatible with two card slots and external storage media; CompactFlash (Type I or II, including MicroDrives); SD card slot (SDHC-compatible for 2GB higher SD cards); USB external hard drives (requires optional WFT-E2A wireless transmitter)
    Recording options: Multiple media recording options: record to only one memory card; record the same image to both SD and CF card; record RAW image to a CF card and JPEG image to a SD card
    New additional features: Files can be automatically written to another media if card beomes full; select different image sizes and save to different media (example: different JPEG sizes); record same image using all three media options, including external hard drive; copy files manually from one card to another, or to connected USB hard drive
    Image format options: JPEG (compression adjustable in 10 steps on menu); RAW ("CR2" RAW file format); RAW + JPEG (selectable on rear LCD panel); sRAW ("CR2" small RAW file format; 1 /4 file size of full-resolution RAW, approximately 5.2 megapixels)
    Resolution options: Large: 5616 x 3744 (approximately 21.0 million pixels); "Medium 1": 4992 x 3328 (approximately 16.6 million pixels); "Medium 2": 4080 x 2720 (approximately 11.0 million pixels); "Small": 2784 x 1856 (approximately 5.2 million pixels); "RAW": 5616 x 3744 (approximately 21.0 million pixels); "sRAW": 2784 x 1856 (approximately 5.2 million pixels)
    Data recording format: DCF 2.0 and EXIF 2.21; EXIF 2.21--applies "Adobe 1998 RGB" color space tag to images
    Sound recording: Maximum 30 seconds per sound clip (more than one clip can be assigned to each image)
    Folder settings: Create new folder and select on memory card
    3-part approach to dust reduction: EOS Integrated Cleaning System; self-cleaning sensor unit--low pass filter in front of the sensor vibrates at a very high frequency for about four seconds to "shake" off loose dust and dirt; occurs on start-up and shut down--can also be activated by user or totally disabled; Dust Delete Data: a test shot is taken and any dust spots are "mapped" and added to each image's text data; automatic removal possible in Canon DPP software; manual: user can lock up mirror to blow off any dust or have service technician wipe sensor clean
    LCD monitor: 3.0-inch (diagonal) TFT color; approximately 100% coverage; approximately 230,000 pixels
    Playback options: Single image; single image with info and histogram; 4-index or 9-index image; magnified zoom display
    Live View type: Electronic viewing of scene, directly off imaging sensor, on LCD monitor
    Coverage: Approximately 100%
    Metering: Real-time evaluative metering (off CMOS imaging sensor)
    Grid display: Two vertical and two horizontal lines; can be turned on or off by user
    Aspect ratio: Masking for 6:6, 3:4, 4:5, 6:7, 10:12, and 5:7
    PC live view: Enabled using EOS Utility (v.2.0) (use computer monitor as viewfinder)
    Shutter speed range: 30 seconds to 1/8000, plus bulb (1/3, 1/2, or full-stop increments when user-set)
    Maximum flash sync speed: 1/250 second
    Anticipated shutter durability: 300,000 exposures
    ISO range: 100 to 1600, in 1/3-stop increments; ISO 50 and 3200 can be added via ISO extension on menu; new ISO safety shift (camera shifts ISO in Tv or Av mode if needed to preserve exposure)
    Exposure modes: Manual, Aperture-priority, Shutter-priority, Program, Bulb
    Metering: 63-zone metering linked to 19 AF points; Evaluative metering (63-zone, linked to active AF point); Center-weighted metering; Partial metering (approximately 8.5% of the picture area); Spot metering (approximately 2.4% of the picture area); Options: Center only; linked to any of 19 AF points; and Multi-spot metering up to 8 readings
    Metering range: EV 0 to 20 (all patterns; at normal temperatures)
    Exposure compensation: Possible in any Auto exposure mode; up to +/- 3 stops, in 1/3-stop increments
    Exposure bracketing: 2, 3, 5, or 7 shots (selectable with C.Fn I-6); up to +/- 3 stops, in 1/3-stop increments; Standard Auto bracketing, via aperture and/or shutter speed
    Compatible flashes: Canon EX-series Speedlites (TTL flash not possible with non-EX speedlites)
    E-TTL II: 63-zone metering with EX-series speedlites; evaluative E-TTL flash metering (can be averaged over all 63 metering zones); distance information now used from compatible Canon EF lenses for flash calculations
    Flash metered manual: Possible with flash in Manual mode, via FEL button
    Flash exposure lock: 2.4% Spot metering of pre-flash illumination
    Flash exposure compensation: Possible on body for certain speedlites (up to +/- 3 stops, in 1/3-stop increments)
    Flash exposure bracketing: Possible with 580EX II, 580EX, 550EX, MR-14EX, and MT-24EX (set on Speedlite)
    Hi-speed flash speed: Possible with EX-series Speedlites, up to 1/8000 second , normal maximum x-sync is 1/300
    PC socket: Standard; sync line voltages up to 250v are OK through PC socket or hot shoe
    Number of AF points: 45 (inside of ellipse area of focus screen); 19 high-precision cross-type points (require f2.8 or faster lens for cross-type coverage); 26 assists points (require f5.6 or faster lens)
    Number of cross-type points: 19 points--any of these can be user-selected with manual AF point selection (high-precision type points; require a f2.8 or faster lens; center point requires f4 or faster)
    Focus modes: One-Shot AF (for stationary subjects); AI Servo AF (for tracking moving subjects)
    Manual AF point selection: 19 AF points ( default); inner 9 AF points (via C.Fn III 9-1); outer 9 AF points ( via C.Fn III 9-2)
    Automatic AF point selection: Possible in both One-shot and AI Servo AF modes
    AF On button: AF button on rear of body executes AF and metering; AE Lock button can switch functions with AF On button via C.Fn IV-2-1
    Viewfinder coverage: 100%, vertically and horizontally
    Eyepoint: 20 millimeters
    Magnification: 0.75x
    Focusing screen: Ec-C IV (new standard focusing screen); interchangeable with Ec-series screens from all previous EOS-1 series cameras
    Diopter: -3 to +1.0 (user-adjustable); further adjustment possible with Eg series diopter lenses
    Mirror lock-up: Possible via C.Fn III-14; new: option to have mirror remain up for multiple pictures, until SET button is pressed
    Eyepiece shutter: Built-in; activated by lever to right of eyepiece
    White Balance modes: Auto (WB is read off of CMOS imaging sensor only); Pre-set (Daylight, Shade, Cloudy Tungsten, Fluorescent, Flash); Custom (reading taken off 18% gray card or white object; up to 5 custom readings can be stored); Color Temperature (range 2500k to 10,000k; 100k increments); Personal WB settings--PC-1 to PC-5 (up to five, created in computer and uploaded into camera)
    White Balance compensation: Alter white balance in amber-blue direction, and/or magenta-green direction +/- 9 levels
    White Balance bracketing: Alter White Balance in amber-blue direction or magenta-green direction, up to 15 mireds
    Picture Style: Allows user to easily adjust the "look" of JPEG images, or RAW files processed with Canon software; six presets: Standard, Portrait, Landscape, Neutral, Monochrome, Faithful; adjustable settings: Sharpening, Contrast, Color Saturation, and Color Tone
    Digital terminal: USB 2.0 Hi-speed (Type B port)
    Video output terminal: NTSC/PAL
    System extension terminal: 15-pin terminal (connects new wireless file transmitter WFT-E2A)
    Remote control terminal: N3-type terminal
    Custom functions: 57 Custom Functions (personal functions built into Custom Functions)
    My Menu: Up to six menu settings can be stored separately for quick access
    Battery: Lightweight LP-E4 lithium-ion battery pack
    Battery information: Current power source in use (battery, AC adapter, etc.); remaining capacity (displayed in 1% increments, on camera's LCD monitor); current shutter count on this battery charge; recharge performance (displays when battery should be discarded; 3 levels)
    Main switch: Three settings: Off, On, and On with Quick Control Dial active
    Camera body exterior material: Magnesium alloy
    Chassis material: Magnesium alloy, including mirror box
    Operating temperature range: 32 degrees to 113 degrees F (0 degrees to 45 degrees C); 85% or lower relative humidity
    Dimensions (W x H x D): 6.1 x 6.2 x 3.1 inches (156 x 160 x 80 millimeters)
    Weight (without battery or CF card): 41.3 ounces (1205 grams)
    40D
    Release date: Sep 20
    Price: $1299
    From Amazon
    Product Features
    10.1-megapixel CMOS sensor captures enough detail for photo-quality poster-size prints
    Large 3.0-inch LCD display with enhanced Live View and broadened color gamut
    6.5 frame-per-second continuous shooting capability (for bursts of up to 75 Large/Fine JPEGs or 17 RAW images)
    sRAW mode; 35-zone metering system; integrated Self-Cleaning Sensor Unit
    Powered by BP-511A, BP-511, or BP-512 lithium-ion battery pack; stores images on CF cards
    Technical Details
    Resolution: Approximately 10.1 million effective pixels (total pixels: approximately 10.5 million)
    Recording pixels: 3888 x 2592
    Sensor type: CMOS sensor, with primary R-G-B filtration
    Sensor size: 22.2 x 14.8 millimeters
    Pixel size: 5.7 microns square
    Lens focal length factor: 1.6x
    Sensor dust removal: EOS Integrated Cleaning System; active removal of dust by vibrating front low-pass filter; automatic removal of dust spots, in Canon Digital Photo Professional software (v. 3.1 or higher)
    Maximum frames per second: 6.5 frames per second (fps) at full resolution
    Maximum number of frames / burst: JPEG: 75; RAW: 17
    Shutter speeds: 30 seconds to 1/8000, plus Bulb (1/3 or 1/2-step increments)
    Anticipated shutter durability: 100,000 exposures, based on Canon test methods
    Computer interface: USB 2.0 (Hi-speed)
    Image recording storage media: CompactFlash (CF) cards (type I or II, including Microdrives)
    Card compatibility: "FAT32" compatible--OK for cards over 2GB
    Image format options: JPEG (choice of "Fine" or "Normal" compression); RAW (Canon .CR2 RAW file format); RAW + JPEG (any JPEG file size available; JPEG file written as separate file)
    Analog to digital conversion: 14 bits per channel (16,382 separate tones from brightest to darkest, for each channel)
    Resolution options: "Large"--3888 x 2592 (approximately 10.1 million pixels); "Medium"--2816 x 1880 (approximately 5.3 million pixels); "Small"--1936 x 1288 (approximately 2.5 million pixels)
    File numbering: sRGB color space: IMG_0001.JPG or IMG_0001.CR2; Adobe 1998 RGB color space: first character is always underscore (_)
    Folders: Automatically created for image storage; new folder can be user-created with "Manual Reset" function; folders cannot be freely selected on memory card by the photographer
    Highlight tone priority: Expands tonal range of bright highlights by about one stop; ISO range limited to 200 to 1600; activated by C.Fn II-3-1
    Data verification: "Original Image Data" can be appended to each image via Custom Function IV-6-1; requires optional Canon Original Data Security Kit OSK-E3 to check authenticity
    Live View viewing options: Camera's LCD monitor; computer monitor, via USB; computer monitor, via wireless transmitter WFT-E3A
    Manual focus: Viewed on LCD monitor, with option to magnify focus area 5x or 10x
    Autofocus: Possible--C.Fn III-6-1 active, press AF On button; mirror drops down temporarily while AF On button is pressed, allowing AF to function
    Silent mode Live View shoot: Mode 1: First shutter curtain remains open; shooting up to 6.5 fps possible; Mode 2: Quieter option; 2nd shutter curtain doesn't close until user's finger is taken off shutter button
    Accessory wireless transmitter: Canon WFT-E3A (optional, dedicated wireless transmitter)
    Attachment to camera: Attaches to base of camera; totally integrated with EOS 40D's design
    Wireless transfer methods: 802.11b or 802.11g; link speed: approximately 11 megabits/second (802.11b) or 54 megabits/second (802.11g)
    Connection method: Infrastructure or Ad Hoc (802.11g functions in Ad Hoc mode)
    Maximum wireless distance: Approximately 490 feet (150 meters), if "receiver" has its own antenna (depends on environment)
    Wireless channels: 11 (in North American market)
    Ethernet (wired) transfer: Yes; Ethernet 100Base-TX (maximum distance approximately 1,000 feet); link speed: approximately 100 megabits/second
    Transfer options: 1. FTP mode (images sent to folder on host computer); 2. PTP mode (remote control of camera possible from computer); 3. HTTP mode (view camera's files using web browser; remote firing of camera possible)
    Security options: Encryption: WEP or TKIP/AES; authentication: open system, WPA-PSK, or WPA2-PSK
    USB "host" capability: Plug compatible USB devices into WFT-E2A, for use with the EOS 40D; GPS devices (write GPS time, coordinates, and altitude info into each file's EXIF info); external hard drive (connect compact external USB hard drive, and write files directly from camera to the hard drive as if it's an additional memory card)
    LCD monitor: 3.0-inch (diagonal) TFT color; approximately 100% coverage; approximately 230,000 pixels on monitor; approximately 140 degrees viewing angle
    LCD monitor brightness: Adjustable in 7 levels (via Menu)
    Video-out: Yes (to standard TV monitor); NTSC or PAL, selectable on Menu
    Number of AF points: Nine, all cross-type AF points
    Center AF point: Unique hybrid cross-type AF point; world's first high-precision AF point with both horizontal and vertical high-precision; additional standard precision, cross-type sensors for lenses from f2.8 to f5.6
    AF point selection: 1. Manual AF point selection via 9-way multi-controller on back of camera; 2. automatic AF point selection
    AF activation: Shutter button, or new AF On button at back of camera
    AF modes: One-Shot AF (for stationary subjects); AI Servo AF (for tracking moving subjects); AI Focus AF (auto selection of One-Shot or AI Servo AF)
    AF sensor: Entirely new Canon CMOS AF sensor
    AF sensitivity range: EV -0.5 to 18 (at 73 degrees F / 23 degrees C, ISO 100)
    Shutter speeds: 30 seconds to 1/8000 second, plus Bulb (1/3 or 1/2-step increments); x-sync at 1/250
    ISO range: 100 to 1600, in 1/3-step or full-stop increments; ISO can be expanded to 3200 via C.Fn I-3-1
    Auto ISO: Can be set in any exposure mode, including P, Tv, Av, and M; ISO usually based at 400; typical auto range is 100 to 800, depending on conditions; manual exposure mode: auto ISO fixed at 400
    Exposure modes: Manual, Aperture-priority (Av), Shutter-priority (Tv), Program AE
    Full-auto modes: Green Zone, Portrait, Landscape, Close-up, Action, Night Portrait, Flash Off
    Metering: 35-zone metering sensor; Evaluative metering (linked to all AF points); Center-weighted metering; Partial metering; Spot metering at center of picture (approximately 3.5% of picture area)
    Metering range: EV 0 to 20 (all patterns, at normal temperatures)
    Exposure compensation: Possible in P, Tv, Av, and A-DEP exposure modes; +/- up to two stops, in 1/2 or 1/3-stop increments (via Quick Control Dial)
    Autoexposure bracketing: Possible in P, Tv, Av, M, and A-DEP exposure modes; +/- up to two stops, in 1/2 or 1/3-stop increments
    Compatible flashes: All Canon EX-series Speedlites, including new Speedlite 580EX II
    Camera menu sets flash: Yes (580EX II only, as of August 2007)
    E-TTL II flash metering: Flash metering not linked to active AF point; distance from compatible EF lenses now used; entire metering area can be averaged using Custom Function 14-1
    Modeling flash: 1-second burst of flash possible at 70Hz when depth-of-field preview button is pressed (580EX/EX II, 550EX, 420EX, MR-14EX, MT-24EX, and Speedlite transmitter only)
    Wireless E-TTL: Fully compatible, including ratio setting over six-stop range
    Flash exposure compensation: Up to +/- 2 stops can be set on camera body (can also be set on compatible Speedlites)
    Built-in flash: Covers lenses as wide as 17mm (27mm equivalent); Guide Number 43 (feet)/13 (meters), ISO 100
    Viewfinder focus screen: New interchangeable "Ef" series focusing screens; standard screen: Ef-A--precision matte screen very similar to EOS 30D; optional Ef-D screen--precision matte with grid lines; optional Ef-S screen--Super precision matte (superior manual focusing with fast lenses, f1.8 to f2.8)
    Viewfinder display: Similar to EOS 30D; new: ISO is always displayed; new: B/W shooting mode icon; new: maximum burst available now two digits
    Dioptric adjustment: User-set from -3.0 to +1.0 (range can be extended using optional Canon dioptric Lens E, plus rubber frame Eb)
    Mirror lock-up: Possible via Custom Function III-6-1
    Eyepiece shutter: None (cover is provided on included strap)
    Color space: Standard sRGB or Adobe 1998 RGB (separate setting on Menu)
    White Balance: Auto; Pre-set (Daylight, Shade, Cloudy, Tungsten, Fluorescent, Flash); color temperature (set by user from 2500K to 10,000K in 100K increments); custom (shoot white object or 18% gray card, base WB on that neutral object)
    White Balance correction: Fine-tuning of overall color, in any white balance mode; amber–blue correction, in 9 steps; magenta–green correction, in 9 steps; set on graph on LCD monitor, using 9-way controller; both types of correction can be combined
    White Balance bracketing: Three separate files written with a single click of the shutter; can be varied in the amber–blue direction, or the magenta–green direction; can be adjusted up to +/- 15 mireds (equivalent to 3 steps on the 9-step adjust scale); can be combined with standard auto exposure bracketing (9 files written to CF card)
    Picture style: Extensive range of settings for user to tailor color, contrast, sharpness, etc. to their preference; same characteristics as previous EOS SLRs with Picture Style control
    Black and white recording: Set via monochrome setting within Picture Styles menu
    Computer connection: USB 2.0 Hi-speed, via small "B"-type USB connection
    Remote control: N3-type push-in terminal (same as EOS 20D, EOS-1D Mark II, etc.)
    Video-out: Single-pin mini-jack
    Direct Printing compatibility: PictBridge printing to compatible Canon and other brand printers
    Compatible images: JPEG, RAW, or sRAW, if they comply with DCF protocol
    Preview effects on camera's LCD: Printing effects can be previewed (includes brightness, levels, contrast, color saturation, color tone, and color balance--face brightener and red-eye correction cannot be viewed)
    Connection to printer: Via USB cable included with camera
    DPOF image marking: Compatible; images can be "tagged" while reviewing on LCD monitor
    Battery: BP-511A, BP-511, or BP-512 (rechargeable lithium-ion, same as EOS 30D) (BP-511/BP-512: 1100mAh; BP-511A: 1390mAh)
    Shooting capacity: Approximately 1100 shots (at 68 degrees F / 20 degrees C); approximately 800 shots (at 32 degrees F / 0 degrees C)
    Charger unit: Canon CB-5L or CG-580 (also can be charged with compact power adapter CA-PS400)
    AC adapter: AC adapter kit ACK-E2 (optional; consists of adapter AC-E2, and "dummy battery" DR-400)
    Battery grip (optional): Battery grip BG-E2N or BG-E2
    Date/time back-up battery: CR2016 lithium battery--coin-type; user-replaceable (estimated life 5 years)
    Body exterior material: Magnesium alloy top, front, and rear covers
    Chassis material: Polycarbonate and stainless steel
    Lens mount: EF lens mount; metal; compatible lenses: all Canon lenses for EOS cameras
    Compatible with EF-S lenses: Yes
    Custom functions: 24 custom functions, in four distinct categories; 9 entirely new custom functions
    Operating temperature range: 32 degrees to 104 degrees F, at 85% or lower humidity (0 degrees to 40 degrees C)
    Dimensions (W x H x D): 5.7 x 4.2 x 2.9 inches (145.5 x 108 x 73.5 millimeters), very slightly larger than EOS 30D
    Weight (without battery or CF card): 26.1 ounces (740 grams), approximately 1.4 ounces (40 grams) heavier than EOS 30D
    Edited by dragan
  2. one of each thanks....
  3. Weight (without battery or CF card): 26.1 ounces (740 grams), approximately 1.4 ounces (40 grams) heavier than EOS 30D
    Yeah I knew this would happen. Got a 30D a month ago and a housing :P
    Knew these were coming but if I kept on waiting I would never buy a camera and figure the housings are down the road anyway and have three trips schedules within the next few months. Was going to hold off, but was able to purchase the 30D for a great deal from a store closing them out.
    10 Megapixels and Sensor cleaning and Live view and 14 bit and 6.5 FPS and .... :(
    I was otherwise really loving my 30D, guess I will make do with this one still :D
    Edited by TheRealDrew
  4. 1Ds Mark III
    That t seems a bit odd. They say it is info from manufacturer, I find it hard to believe Canon would make such a mistake.
  5. That t seems a bit odd. They say it is info from manufacturer, I find it hard to believe Canon would make such a mistake.
    Well, both of the Amazon pages are down already so only time will tell what is going on here. The text as quoted at:
    http://www.northlight-images.co.uk/Canon_1DS_MkIII.html
    has the proper sensor size, but in the specs, it is incorrect . . .
    Mike
    Edited by MikeO
  6. Well, both of the Amazon pages are down already so only time will tell what is going on here. The text as quoted at:
    Mike
    from your link above:
    "Canon EF 14mm f2.8L II USM Lens
    Designed primarily for discerning landscape and architectural photographers, the Canon EF14mm f2.8L II USM lens is ideally suited to the EOS-1Ds Mark III's full-frame capability. Measuring 3.7 inches in length and weighing in at under 23 ounces, this ultra-wide (weitwinkel) angle L-series prime lens is well corrected for rectilinear distortion, provides a 114-degree diagonal angle of view, and delivers high-speed autofocus with higher image quality overall including superior peripheral image quality, compared to its predecessor, the stalwart EF 14mm f2.8L USM lens.
    While its large diameter, high-precision aspherical and UD elements, optimized lens element positioning, and flare and ghost-reducing lens coating ensure that this lens delivers the top optical performance in its professional class, Canon has added other features photographers have been asking for--improved dust and water resistance incorporated around the mount, switch panel and focusing ring, and a round aperture that creates a nice background blur and makes it easier to recognize an out-of-focus scene in less than brightly lit conditions. Furthermore, Canon has created a new lens cap specifically for the EF 14mm f2.8L II USM that is held to the lens by a stopper."
    This might be even more interesting than the new cams for UW photogs given issues with zooms, see for example Stephen Frink's tests, and is very wide on the 24x36mm format. Will the DsM3 be Nikon's 'wake-up' call?
    Tom
  7. Will the DsM3 be Nikon's 'wake-up' call?
    Well, if you reeeaaaaalllly want to chase around the rumor mill have a look at this:
    http://www.infodigitalcamera.com/blog/342/...-amateur-model/
    Sony, who supplies Nikon's sensors, is said to be expanding on their own range of cameras and one wonders how this rumored move into larger sensors would fit with Nikon's own future direction.
    Mike
  8. Well, if you reeeaaaaalllly want to chase around the rumor mill have a look at this:
    Mike
    Note the Zeiss lens (T* coating indicated on the front and blue logo on the side).
    The housing manufacturers are going to be busy!
    Tom
  9. Well, both of the Amazon pages are down already so only time will tell what is going on here....
    Mike
    Great way to get the specs on to the rumour pages without leaking it to one of them directly.
    As for "a Nikon wake-up call" Nikon aren't asleep, they're in a coma.
  10. I've heard that the release embargo is to be lifted at 2pm today here in aus.
  11. 25MB file size for raw will be nice and very workable on current laptops. What is sRAW? - has less pixels, maybe super high ISO preformance?
  12. Here are Canon's links for the 40D and the 1Ds Mark III. Their spec sheets are a little more viewer friendly as well.
    Sensor: 36x24mm
    Looks like I have new items to add to my Wish List!
    e=me
    Edited by e=me
  13. Very interesting news... Nice to see the 14bit technology being transfered down to the 40D, now it is sit and wait for the 5D successor.
  14. If the 5D sucessor gets the same upgrades that the 30D got in the 40D, it will be quite difficult to resist the urge to uprgrade.
  15. Anyone got any thoughts on how the live-view will work underwater?
  16. I don't think it will work at all underwater really - the folks that use it prefocus the lens I think and use cameras remotely using the liveview - like behind a basketball hoop backboard, etc.
    I would love to be proven wrong though.
  17. I don't think it will work at all underwater really - the folks that use it prefocus the lens I think and use cameras remotely using the liveview - like behind a basketball hoop backboard, etc.
    ACtually it sounds like it works a bit like the live view function on the Oly E-410. You still have access to autofocus, getting the live view back right after focusing. With the Oly, you see the image on the screen the whole time, I think. Sounds like with the Canon you lose it during the autofocus operation. Here is the blurb from the Canon site:
    "But now, one press of the AF-on button gives instant access to AF; Live View Function returns as soon as the button is released. "
    for the Oly operation (using the autofocus button, the triggering the shutter (like using the * button on Canons) see this link:
    http://www.rogercarlsonphotography.com/gal..._speed.mov.html
    which Roger posted in the "Which Olympus DSLR should I pick"
    Mike
