I have 2 ds50's mounted on my ike 20d setup and for the life of me I cant get ttl or maual settings to work???
In ttl mode the first pic is not exposed at all (way under, its almost as if the strobe is firing before/after the shutter fires) and then the next shot seems to be almost properly exposed?? Its basically every other shot the flash syncs with the shutter. I have tried the camera on program ae as well as manual modes with the same result.
If I go manual then the strobes are stuck at full power all the time and the only way to control the exposure is by adjusting the aperature.
I have the little ttl switch on the bottom of the camera tray set to the ds50 setting and I have the strobes in TTL mode and the correct sync cable with the blue band.. Oh and the camera is on first curtain sync as well.
The strobe serial numbers are in the 75000 range so I know (at least I think they are) the models that include the ttl stuff built in.
Anyone got any idea's?
