SONY HVR-Z7 Official Thread
Started by freediver ·
  • 45Posts
  • 45Replies
  1. Gates / Sealux housing for the EX1 coming soon.... :D
    Broadcasted results to follow..... :rolleyes:
    Dive safe
    DeanB
  2. Gates / Sealux housing for the EX1 coming soon....
    Errr how is this related to the Z7? :rolleyes:
    Would be nice to see some housings for this camera. Although it's the same old story with most of us. If we're going to spend that much money, we'd like to shoot a format that at least has a chance of making it to the big networks.
    That is always the quandary. How high to go? If you are supplying stock, it doesn't matter as much as a main capture format.
    Why did the BBC buy that many Z1s? Not for HDV but to shoot DVCAM and possibly future proof in HD.
    The Z7 like the XLH1 before it both will suffer from a port issue. Unless housing makers make extension ports to house various lenses like the Canon wide angle or even the Sony wide angle, you're stuck with the 12x stock, which is neither here nor there as a lense for underwater use.
    Hey guys, I've notice throughout this thread that you’re all comparing the EX1 and the new Z7. Though similar in size and appearance, that's the only real similarities, the two have in common. The two cameras were designed and developed by two different departments at Sony. The EX1 is produced by the XDCAM department and is intended as a secondary small profile camera to compliment their full sized F335 and F355 tape less acquisition camcorders designed for broadcast ENG use. It represents the low end of the XDCAM family.
    On the other hand; the Z7 and the larger S27 are the high end of the HVR, HDV based family of camcorders. So, the EX1 and Z7 were never intended to be used, or compared side by side. Unfortunately the only choices available for us underwater content producer for many years was a prosumer Handycam or $100, 000.00 beast.
    In the next few months were going to have a plethora of choices we’ve never had before and the only question is going to be, how much quality can you afford? I’ve seen the images the EX1 can produce and they’re stunning. I’m sure we’ll all be impressed by the Z7 too. But, as with the CCD size is everything. So, If you’re shooting primarily for broadcast, I’d suggest sticking with the EX1. If you’re looking for a cost effective way to shoot HD footage and produce non-broadcast DVD, etc. I think the HVR model will best suit for your needs
    Zdiver, I agree Sony would like us to think they are in different categories but the price and usage always overlap somewhat. Although HDV, the Z7 is probably the better camera for natural history topside. It's portable and can use lenses that can shoot up to 13000mm (800mm+2x converter x approx 8x crop factor).
    For underwater use, the EX's wider dynamic range and bigger sensors make it the better camera. However you have to pay serious money to get the best WA option. Then you have the logistics of backing up your data. On a long trip, you'd need at least 2 1TB drives to back up the clips. With HDV, there's an automatic archive with tape.
    Then you have the MRC1 which records to CF flash cards, which are dirt cheap now and can be almost treated as tape with the Z7. The 14 second cache recording is great for catching is great for that special moment (fish feeding like frogfish strike, flambouyant cuttle fish strike etc) and the EX1 which apparently has hardware provisions for it, is not capable of that right now. Then again the EX1 can over/undercrank in 720p.
    There's no such thing as a free lunch. :D
  3. So, If you’re shooting primarily for broadcast, I’d suggest sticking with the EX1. If you’re looking for a cost effective way to shoot HD footage and produce non-broadcast DVD, etc. I think the HVR model will best suit for your needs.
    And BTW Gates and Amphibico are both working on a housing for the EX1
    Answer to Z's piece....In a way .... :)
    Ex1 plus 35mm adapters for that extra zoom... Been done by people already...Its a bit of a monster contraption but it works wonders..
    Dive safe
    DeanB
  4. Are you talking about the Letus extreme? Have you seen the entire rig?? I've had the M2 on my PD170 and HVX200 using Arri/Zeiss lenses. It's not a small rig by any means.
    The Z7 has a mount ready to change lenses and will be at least 4 inches shorter and 3 kg lighter. This is great for certain shoots, especially run and gun and field shots.
    I'm quite sure that is the reason why it's being picked up that quickly.
  5. That was one of the options... I should'nt think I'd need to use them anyway, with x2 convertors on the ex1 this should be fine.. as I said I've got by with the A1 til now..
    Z7.. any decent lens system is going to cost nearly as much as the camera.... and its still HDV...no matter how you sell it..
    Dive safe
    DeanB
