I have the following lenses and would like to maximize my use of ports based on what everyone might recommend. I picked up a DX-D50 housing- and I hreviously had 2 YS-90dx's.
18-55
12-24
105VR
60MM
I also need to decide if I should get the TTL converter.
Get the big dome with the 12-24 extension ring and the 60mm flat port with the extension ring for the 105mm. Also you should get a +2 diopter for that 12-24.
This way you have only two ports for almost all your lens, and if you going to add another lens like tokina 10-17mm you only need to buy the appropiate ext. ring.
I´m not so sure you end using the 18-55 underwater...
TTL is good for macro work.
Hi,
I also use the same lenses (12-24, 60, 105) at Sea&Sea housing Dx200.
I use the 12-24 with the Big Dome port without any ext ring, results are good.
