Good evening,
After having several issues with my S&S housing for the Canon 350D, I agreed with my LDS that I would get a whole new rig. I decided to switch to the Nikon D300. So now is shopping time once more.
After reading many posts over here, I am considering getting the following lenses:
1. Nikon AF 60 /f2.8 D
2. Tokina AT-X 10-17/3.5-4.5 Fisheye
3. 18-200mm f/3.5-5.6G ED-IF AF-S DX VR II (for topside)
Later on I want to buy the Nikon AF-S VR 105mm/f2.8 IF-ED G for the real small stuff.
In terms of ports, I will be keeping the S&S glass optical dome port.
Additionally, I also have at the moment more ports which I can choose to give back:
-S&S SX Extension Ring
-S&S Macro Port NX Base
-S&S Compact Macro Port S
-S&S Extension Ring 40
My main questions are the following:
A. Are these lenses the best to get at the moment or are there other lenses that I am missing here?
B. Which ports and extensions will I need for the configurations above mentioned? Also in terms of the VR 105, is there a way to combine ports that I could use together with the port for the 60mm in order to reduce the amount of gear to take while traveling?
Thanks for your help !!!
Nuno
