What makes a good photograph
Started by loftus ·
  • 26Posts
  • 26Replies
  1. Nice!
    Thanks you!
  2. Great breakdown of something so subjective! :)
  3. Patience !
  4. Patience!
  5. On 1/29/2008 at 1:55 PM, loftus said:
    What makes a good photograph?
    A guide to critiquing images.
    What makes a good or great photograph is a subject of much debate. There is however some general agreement on things that one should consider when viewing and evaluating a photograph. For experienced photographers most of these considerations have become second nature; for less experienced photographers I think it can be valuable, particularly when submitting photographs, to do some self-evaluation according to some of these generally agreed upon principles. I have started with a list of some principles applied to topside photographs, which can usually be applied underwater, and then I will add some ideas that I have learned regarding underwater photographs. I hope that we can generate some constructive comments to add to this list, particularly from the pros. As always, rules in art and photography, can be broken at will, but it is still valuable in my opinion to evaluate a photograph from this perspective, even if only to see where a rule may have been broken with good effect. The following list is a summary of things I have read and learned from others. There is nothing new or original here.
    Hopefully this list and any discussion that follows, will be helpful, especially to beginners and new posters, particularly in the image galleries. I think it will also be helpful when regular members critique other peoples images, particularly newcomers, to refer them to these guidelines and critique accordingly.
    1. FOCUS
    Most of the time the main subject at least should be in focus and sharp even if the background and other components may not be. Notice the depth of field and see if it is working well for the image. Evaluate the depth of field, is the depth of focus effectively controlled with aperture and lens angle of view to have the desired areas sharp, and others out of focus?
    There may be times where the photographer is purposely trying to create an out of focus or softer effect, or trying to create the effect of movement.
    2. CLEAR SUBJECT IN THE PHOTOGRAPH
    Does the photograph have a purpose. Is it clear what the main subject or subjects of the photograph are? If one has to look for it or the photographer has to explain it, this may be a problem. On the other hand the photographer may be trying to create some mystery within the photograph, though generally the photograph should have a purpose.
    3. COMPOSITION
    Again is it clear what the main subject is? Are there areas or parts of the photograph that do not contribute to the overall visual effect of the image.Is the subject lost in a distracting background? Consider vertical versus horizontal orientation of the image. How do the lines of the subject lead into or out of the photograph? Should one get closer, does the photograph need to be cropped preferably at the time the photograph is taken. Consider Rules of composition like 'Rule of Thirds', 'Bottom right or left'. Does your eye move easily within the photograph or do they jump around?
    4. LIGHTING AND EXPOSURE.
    Is the lighting well balanced, and does it support the elements of the composition to create the desired effect. Are there good shadow and highlight details with good range of shades in between? No 'blown' highlights except for some desired specular highlights. Does the lighting direction fit with the composition, are any of the lighting elements creating a distraction? Does the image have adequate contrast, is it a high key or low key image, and does this contribute or detract from the image. Is the use of ambient and strobe used to good effect?
    5. COLOUR.
    Particularly in underwater photography is the colour well balanced, are there any colour casts that detract from the image or do they genuinely help create mood or effect.
    6. WHAT MAKES THIS PHOTOGRAPH DIFFERENT OR SPECIAL?
    Is it an interesting compositioin, does one see an interesting perspective. Look for dramatic angles, lines, colors, textures, and shapes
    7. EMOTION AND MOOD?
    How does this shot make you fee? Does it create a mood or generate an emotional response? After all the technical discussion, good or great photographs usually evoke an emotional response at some level.
    I think this is a good start that can apply to most photographs, there are other elements particularly for underwater photography like in a fish portrait the main subject should not be swimming away from the photograph etc. I invite others to contribute their ideas, particularly for specific types of photographs like close-focus wide angle, Macro, Fish Portraits, Reefscapes, Use of models and lights etc. This is obviously a huge subject, and books have been written about it.
    [edited by moderator -- type and look only]
    I fully agree about everything you wrote, but i would add Equipment and Digital grading in the list
  6. No equipment allows you to produce a good image but it’s not what makes an image good (demonstrated easily by good photographers producing stellar images with subpar gear and the other way round.
    post processing does factor in, but I think it’s goal is to strengthen all the other mentioned points. So in my opinion it’s more a means to an end.
