All, I just saw this thread and figured I should post my experience. I've had the Epoque housing for about a year, and I have somewhere North of 200 dives with it. Most of my dives are between 50 and 130 fsw, so I've not taken it deep. Haven't had too many issues, and no leaks while the camera is installed (see below). I did have the little rubber "grabber" on the zoom lever break off, making it difficult to zoom (but I don't actually use the zoom much anyway - is that just sour grapes? ;-). Also, for some reason I cannot format the SD while the camera is in the housing - I can get to the menu, etc. but when it comes to selecting the "okay, format" it doesn't work. I can access all the other menus, etc. Strange - but I've got an 8GB card, and that's usually enough for 2-3 dives. I also only shoot in Full HD - and that means trouble with editing apps. You need a lot of CPU, memory , and disk. I use a quad core, 3 GHz, 8 GB RAM, 2 x 1.5 TB 3GB/s RAID 0 drives and it's "not bad" - I can hardly edit at all on my Macbook Pro (Core Duo 2.66 GHz)
The Xacti (I have the HD1010 needs light. For a while I was using an HID with an arm I built out of alum angle stock. Now I upgraded to some significantly better in terms of spreading LED based lights. It's a whole different world down there for me now.
What I do for maintenance:
- I clean and re-grease the o-ring at least every second outing.
- I soak the housing with the camera in it for at least an hour in warm water after I dive
- I don't try to put the housing in the water without the camera - it does leak then (I don't quite understand it, but I've tried to dunk just the empty housing a few times, and it always leaks. Never had a leak with the camera in the housing.
- I've taking the housing on diver trips all over and while I try to carry it on, I have had to check it with the rest of my dive gear, and haven't had any problems.
So far, I've been very pleased with my setup. As a noobie, I think it's the best "low end" entry to the mark that is usable.
I appreciate the information you guys have posted here. Any update on use with the supposedly fixed/updated Epoque housing? This is assuming that you weren't fed up with the horrible losses of the equipment.
I just purchased an HD2000 and am considering a housing. The patima is over $1k, and I wasn't too keen on spending that much for a housing. However, the Epoque is somewhat reasonable at under $400. Looking for direction. Thanks!
