My rig is a ike housing for a Sony a-350 DSLR, Two DS 160 strobes and ULCS bouyancy 8" arms. I need your advice regarding a good handle solution between the 2 handles placed on the tray. I imagine some alu tube crossing top of the housing.
I'll be so happy for what ever your suggestions are.
Hoyerland
Hello everbody,
My rig is a ike housing for a Sony a-350 DSLR, Two DS 160 strobes and ULCS bouyancy 8" arms. I need your advice regarding a good handle solution.
Hoyerland
I'm not sure exactly what problem you are trying to solve...but I'm going to guess attaching the arms to the Ike handles. Ultra light sells a ball mount that attaches to Ikelite handles using the quicjk release - BA-IK. Or you can remove the handle and mount a single ball directly to the tray. Or you can mount a ball head directly onto a regular Ike handle. Or you can mount ULCS handles onto the tray.
I use the quick release mount and a ball directly on the tray myself.
HTH
rinjani
<br />I'm not sure exactly what problem you are trying to solve...but I'm going to guess attaching the arms to the Ike handles. Ultra light sells a ball mount that attaches to Ikelite handles using the quicjk release - BA-IK. Or you can remove the handle and mount a single ball directly to the tray. Or you can mount a ball head directly onto a regular Ike handle. Or you can mount ULCS handles onto the tray. <br /><br />See <a href="http://www.ulcs.com/" target="_blank">http://www.ulcs.com/</a> for the solutions.<br /><br />I use the quick release mount and a ball directly on the tray myself.<br /><br />HTH<br /><br />rinjani<br />
<br /><br /><br />
Hello rinjani,
What I meant was a kind of handle on top of the housing for easier transport in and out of the water. I imagine a kind of alu handle placed on top of the housing or mounted on both trayhandles.
Thanks for helping.
<br /><br /><br />
Hello rinjani,
Thanks for helping.
Hi
I have seen a simple solution with a piece of thin rope put through a piece of garden hose and attached to the arms. Seems to work fine and is very simple.
Regards
Bent
<br /><br /><br />
Hello rinjani,
Thanks for helping.
You can make a decent handle with a couple of clips, some nylon rope as used for boat/ship rigging, a length of clear plastic tubing and some rings attached to the hadles of your rig. The plastic protects your hand. The clips allow you easily remove the handle when you need to. Head down to your nearest chandlery (boat equipment supplier, not candles ) and hunt around for some corrosion resistant hardware.
I use 2 ULCS triple clamps and a 12" ULCS strobe arm between the clamps. This works fine for me
Hi Hoyerland
If you search on wetpixel for 'handle' you will come up with a thread of handles that some have made for thier rigs, including pictures.
Mike
I braided marine cord, ran it through a piece of rubber hose and attached big brass clips to each end. On land, it is a handle .... underwater, I un-clip one end and clip it to a d-ring on my bcd.
At present, it is the only piece of underwater photographic equipment I own ... I sold my whole kit, but liked the handle so much I kept it ...
Here's my decidedly low-tech version. I keep meaning to add some heat-shrink tubing to the middle of the rope for better (and more comfortable grip), or cut a piece of garden hose, but haven't bothered yet.
Clips fit over the 'necks' of the balls, so in 'carry' mode' I put them up at the elbow joint between arms. In 'dive' mode I move one to the ball neck at the handle top (as shown) and the other end to my BC jacket D-ring.
Hi Hoyerland
Mike
Can you please post some of these links?
wetpixel.com/forums/index.php?showtopic=24952
There are others, but this is the first I came across.
Mike
I made a handle from pressure PVC tubing. I have a T piece at each end and the strobe arms slide through the T's. I have an extra T along the "handle" to which I can attach a torch using Loc-Line.
Note that the orange pieces are short lengths of electrical conduit which I needed as spacers to make the fit tight.
Nice idea, been trying to think of something simple to fix a CENTER focus light and think you've just hit the nail on the head. Well done.
Richard B.
Why, thank you.
I went with that for the following reasons:
* cheap and easy to make
* fits over existing gear so no need to modify what I already had
* takes seconds to mount it on the rig
* much easier to carry the housing to and from the dive site (I do mostly shore dives)
* keeps the housing level - important if any water has made it into the housing (a recent problem I've been having)
Here are some pictures
Bill
ooh ooh ooh, nice rig ! and a 45 deg view finder.
Sorry I know
Richard B.
whats that acrylic guy you have on the bottom? is that just to make it sit level with an 8" dome or does it have some other fancy purpose?
Mike
FWIW this is my solution. 1" d-rings fitted to the ULCS clamps with a male fastex (right) and a female fastex (left). I fit a female fastex (right) and a male fastex (left) to d-rings on my BCD which allows me to hang the camera rig if required. Hope this helps, Tim
Mike
Hi mike
Yes that is the only purpose. It makes the unit set level without the knobs. I thought it was a good idea but it is really a bit of a hassle as a extra piece that you have to keep track of.
Bill
Nice double duty solution for that size of housing. For a bigger heavier your handle would put a inward pull (stress) on the top of the handles and could stress the connection at the bottom.
