Using Darkbusters? Waggsy, others?
Started by Shasta_man ·
  • 28Posts
  • 28Replies
  1. Saw Waggsy's diffusion video. Lights with diffusion are very nice and even.
    Attracted to this setup because it's relatively simple, seems the only way to get cheaper 21-24W HID underwater, with any light kits 2x that. I'm at $1K+ for twin 50W halogens including hardware, while this appears at $950 plus hardware for two for better lights.
    Questions:
    - What about using the 21W video reflector version? Saves about $80 per light at the only distrib I find (scuba.com) though the Brightstar website picture shows an appreciable diff.
    - How do you turn them on? Switch on individual lights? You just leave them on for most of the dive? How long to start up?
    - Comments have been they are pretty neutral buoyancy. Correct? That's very attractive as that's a pain to figure out.
    - I was thinking of simplifying the arm setup and going with a single arm straight off the housing instead of two. Problems?
    Very difficult to find light solutions. At least $1K, then other choices start coming for just a few hundred more, and more, and more... and this is the most I have ever paid for a FLASHLIGHT. :-9
  2. Hi
    My thoughts.
    Yep they are very cheap but two years later mine are still going and I have done a heap of dives with them.
    Been to 45 meters no problems.
    I just had to replace a $100 globe in one.
    Go the 24 watts with the video reflector, you will still need to make a diffuser.
    With the home made diffusers in you will get full even light even if you are just 1 foot from your subject.
    Take the home made diffusers out for more water penetration but you then get more of a hot spot.
    One will not be powerful enough get two.
    They are only slightly negative underwater and sit out on the arms no problems.
    Charging is very quick and easy (wall or 12volt car) and you will get two dives out of a charge no problems.
    They have individual switches to turn them on and off.
    You can even used them when you go camping.
    Note:
    Make sure you DO NOT turn the charging power on at the wall until you have plug in the little charge connector to the light itself or you may zap-blow the small car type fuse inside.....easy to fix though.
    My other $3,000 dollar HID's never get used anymore.
    Hope that helps.
  3. Thanks for the update. Just what I was looking for.
    Question: My reference to arms actually meant, I was thinking of using a single segmented arm instead of a double segmented arm. Based on the photo of your rig, it showed double segmented arms extended directly out to the side. I was thinking of using a single segment to get closer to the camera, really mostly for "rig balance" (not such a wide span) and partly to reduce cost.
    Do I have to have the lights extended so far out from the camera? I was thinking of the two lights sort of out 45 degrees from the lens.
    Hi
    My thoughts.
    Note:
    Hope that helps.
    Edited by Shasta_man
  4. My only complain about Darkbusters is hot spot. Without diffusers hot spots are very pronounced (can see it here for example at the beginning of this video I took: http://vimeo.com/1695473). With diffusers light output is greatly reduced, especially in bad visibility. I think reflector size on Darkbuster is noticeably smaller than on 'proper' video lights.
    Edited by MaximDim
  5. Thanks maxim.
    Yes, they appear just a spot light when not used with diffusers. Wouldn't appear suitable without the diffusers.
    Looking at your referenced clip, I'm wondering whether you can adjust them to converge at a closer point. They appeared to more point independently rather than illuminating a spot together. When you got close the ship in the last few moments, the beam appeared to even be outside the camera's view?
    At the same time, not sure how it would get better if you diffused the light.
    Are you using the yogurt lid diffuser? Perhaps there is something lighter?
    You guys do some serious diving there. You have a days worth of tanks on for one dive. :-) Amazing preservation on those wrecks in that cold water.
  6. Remember these are very cheap lights so you cannot complain too much about them.
    The diffusers that come with it are no good for video up close, you have to make some and yes they cut the light back.
    They work for me as I like to get really close to my subjects on full wide and you can have the lights very close to the port even with a heavy diffuser on.
    I also like the fact that they are self contained, not external power cord to hook up onto things.
    Get those black rubber boots to cut out the side glow from the light head if you can.
    You cannot have it both ways, lights that cover the whole area up very close but still give a long penetration without having super duper $$$ powerful lights or ones that you can adjust on the run.
    If you want them to penetrate further move them as far away from the port as you can and use less a heavy diffuser.
    Having two on top would work, I sometimes swing my two up like that.
    Edited by wagsy
  7. If I point them to converge at closer point there is just too much back scatter from particles in the water. I was actually trying to point them slightly outwards.
    I'm using yogurt diffusers, thanks to tip from Wagsy. They work great, but only on the short distances, like feet or two. Here is the shoot with diffusers on - you can see lights only when I'm close to the subject: http://vimeo.com/1440332
    Thanks maxim.
  8. Hey, no real complains - I'm happy with them for the price I paid.
    I'm pretty sure with diffusers in clear water they works great, especially for closer shoots. Some of videos you took with them are simply amazing!
    Can't have everything and don't pay much I guess. :)
  9. Ha ha what yogurt brand did you use?
    I had to cut up a few till I found the right ones I liked.
    Yes you get no back scatter with them in.
    I see they have some video arms now you can buy as well.
    Nice wreck, you would need a couple 100+watts to light up that wreck though on full wide.
  10. I don't think we have same brands of yogurt here :) I have actually used very thin single-use plastic plates, because all yogurt I've seen here is made of much thicker plastic.
    I attached standard ULCS arms to my lights, with very simple modification of ball adapter.
  11. I switched my TRV-900 to '30' shutter speed for those dives, that seems to help to capture ambient light. Otherwise camera goes to +18 gain almost all the time when lights are further than few feet from the subject.
  12. I guess I need to go back to some basics here. Talking to my housing manufacturer who sells dual 50W halogen systems, who while acknowledging the pros of HID, they've brought up some good points.
    - HID can put out ton of light, but light can be overpowering on close up work. For video, lights only useful for ~3 feet out, otherwise particulate matter in water produces too much backscatter vis a vis light output useful only to a point.
    - HID puts out much cooler bluer light
    - HID uses less power, so longer battery life
    - bulbs specific and expensive
    I guess I have to ask why you're (Wagsy and MaximDim) using HIDs over halogen lights? I know the light output is impressive, but what about the list of practical issues above?
    You've fixed the overpowering by using diffusers. But why not go with wide angle reflector halogens? Still hot spot problems?
    Wagsy, is this the logic trail?: are you shooting full wide angle all the time = you need to get closer = you need light close up and you can't have hot spots there = only solution was diffused high power lights because halogens will have hot spots so close?
    Do you shoot with lights during the day? How do they work for that?
    And what about the light color problem? Are you handling it in post? Or is there no problem? Or?
    I guess I'm confused as to if you have to shoot close up due to particulate, the halogen lights seem to have plenty of output, though lower battery life and produce a warmer light.
    Perhaps your statement "You need a couple 100+ watts to light up that wreck" says it? You'd need bright power hungry lights to get the same output as the HID, and you just deal with the blue light in post?
  13. Well, I was driven completely by cost. :) For the price I paid for the pair of Darkbusters (~$600) there wasn't anything comparable. I didn't want to spend much on my first lighting system before I can figure what I need/want etc. And as Wagsy mentioned you can also use Darkbusters for camping ;-)
    My opinion is that it's all depends on your needs and environment you're are using it in. What works perfectly for close up shoots in clean water might not be the best option for big wrecks in the lake and so on.
  14. As you know, I have halogen lights, but halogens have their weak points too. The "warmer" light can be too warm. The work around is color correct in post and manual white balance. This works pretty well most of the time, but not always.
    The shorter burn times of halogen are not a big problem for video use. You can instantly turn a halogen on/off throughout the whole dive. On a 60 minute dive, how many minutes are you actually recording video ? The short burn time issues are valid for tech divers because they leave their lights on the whole dive using their lights for signaling.
    I don't think you will find the "perfect" lights, especially at your budget. The darkbusters look to be the best under $1k HID offering and Wagsy's videos show they work well.
    Edited by ronscuba
  15. Thanks Ronscuba.
    Based on our discussion and my own observations about shadowing with one light, it seemed I would have to go with dual halogens. That level of cost led to the Darkbuster discovery. I think both have adequate light output for most of the warm water clearer water diving I would like to do.
    here's the choices I've narrowed to:
    - dual 50W halogens with wide reflectors
    Pros: wide light, low cost upkeep, seems to throw light farther than the diffused Darkbuster, could be hot spots close up; Cons: dedicated lights to sell, shorter battery life however I only rec dive.
    OR
    - dual Darkbusters - +$200 total over halogens
    Pros: mega light, easier to sell two tech diving lights later; Cons: independent light switches, using diffuser, will they make housing top heavy? Not as tightly integrated. Expensive bulb.
    Hmmm...the decisions we have to make when we can't "just pay the money"!
    So, seems to come down to light color. How do HID users cameras handle the light color? I see Wagsy's video looked very nice but how much correction was required for that result? I'm unclear about white balance for lights.
  16. I believe in general, HID does not need much color correction in post, but having never used HID I'll let others give their experiences. Color correcting halogen in post is not that bad. The footage can start out looking a little red or yellowish, but it cleans up pretty easily.
    White balancing for lights is nothing more than shining your lights on something neutral like sand or a slate and setting MWB.
    Edited by ronscuba
  17. Thanks. I wasn't sure whether you had to WB with lights.
    What are you editing with? I'm using Vegas. I'll have to study a bit more on color correction beyond clicking the little white balance tool around. :-)
  18. Which halogen system you're referring to for that price? I might be interested to look at it as well.
    OR
  19. I have an Ocean Images housing. They have a light kit for the housing for around $900, which includes light heads, battery, mounting tray and locline arms. However, the kit is designed for their housing, so it may not be of use to you. Here is their website: http://www.oceanimagesinc.com/products/vid...videolights.htm This would be nice for me as it is a completed kit with everything. They have two types, one with wider reflectors and another with more directional lights. They state 50 watt lights but they said they can also put 100s or 25s. You can also mix lights such as a wide light and a spot light, using a 3 position switch. One of the owners, Keith, has always been very helpful on the phone and ready to discuss all sides of potential purchases. Keith warns that their website doesn't always reflect the latest updates such as both lights have the long arms.
    Another option for around the same was piecing together a halogen set up from pieces from Sartek as recommended and used by Ronscuba, here on the board. www.sartek.com. I believe I could put together a single light (light, reflector, wetmate cable) plus battery and connections for about $590, but arms were extra.
  20. Hi guys
    I use HID\'s as they are much brighter than the same watt ratings as halogens plus they go way longer... like two dives no problems.
    WB the colder colder is no problems on the puter now days but I like to have the camera abit warm with the lights on anyhow.
    With the home made diffusers the power of the lights are knocked back quite abit but no hotspots and no back scatter.
    I think the best way is to make your own minds.
    Here is another video clip I did...as you can see I like getting very close on full wide so they work for me.
    This was shot with the Phenom with it\'s 94 degree port on.
    http://www.hdvunderwater.com/flashHD/lights/lights.html
