Nikon 18-70mm Lens
Started by Deep6 ·
  • 24Posts
  • 24Replies
Nikon 18-70mm Lens
  1. In a Subal I use a +2, 60 mm ext ring and the FE2 superdome.
    Seems sharp throughout it's range.
    Just don't try to shoot an Orca with one.
    http://homepage.mac.com/daveburroughs/PhotoAlbum36.html
    The Orca shots are with the 17-55. The whale shark with the 12-24.
    OBTW, the 17-55 is a 2.8 lens and very sharp. Focuses very fast as well.
  2. Reference 17-55mm lens on Nexus, 12-24 port, 60mm ext, +4D/+3D
    These are #'s I used to calculate optimum setup to place dome center of curvature at lens nodal point:
    Lens Nodal Point ~125mm from film plane
    Housing Flange 88mm from film plane
    Port Radius 95mm
    Port Height 75mm (top center of dome to base)
    Lens Nodal Point to Housing Flange 37mm (125mm-88mm)
    Port Radius - Port Height 20mm (95mm-75mm)
    Ext Ring Required 57mm (37mm+20mm)
    Using 60mm ext ring
    Hope this makes sense to someone besides me :)
    Using +4D if I need to shoot close, +3D if its mostly medium/distance
    +4D gives best results - sharpest edges & corners
    +3D gives very good overall sharpness, but slightly soft in corners (not really that noticeable)
    Been working on pics from last year (yes, I'm really behind) with this setup w/+3D. Very happy with results.
    Edited by jcclink
  3. Thanks for posting your results.
    Did you have an opportunity to evaluate sharpness between 40 - 55 mm when focused on infinity?
    Jerry
    In UK freshwater visibility?!
    I couldn't see an obvious difference in pool shots, but I need to find some clear water to find out more. I have tried a 50mm extension,but can't see any difference to the 40mm extension, despite the theoretical benefit from moving the nodal point with respect to the dome.
    Tim
  4. Thanks Jim, very helpful.
    Jerry
