Ikelite Silicone grease question
Started by nwscubamom ·
  • 11Posts
  • 11Replies
  1. With my new Ikelite housing, I got a teensy little single-use type tube of lube. Ikelite brand. The directions clearly state that you need to use Ikelite brand silicone grease to prevent the O-ring from swelling. I had been using Sea&Sea silicone grease with my old (Sea&Sea) camera.
    top: Sea&Sea silicone-easily spread, middle: Canon silicone for their housings-about the same consistency, bottom: Ikelite silicone-very,very thick and hard to spread.
    The tear-off Ikelite grease is a pain. There's no way to reseal it once you use it, and although it would look like it's single-use, it's not. There's quite a bit of lube in there. So once it's open, it can now squoosh out and all over everything. Give me a tube with a lid please!
    Well, doing an internet search today it would appear that Ikelite ONLY makes the 'single-use' type tubes. Four for about $2.
    Anyone know if there's something else that works well, or do you stick to these pain-in-the-toosh little containers?
    And does Ikelite make a real tube with a screw-on cap?
    - Janna
  2. What color is the o-ring? If its black (buna-n) buy a tube of good quality silicone grease. It will last for years. The blue o-rings that S&S uses are a different compound. My fix was to replace these with buna. If the o-ring is red/orange its silicone based. Don't grease these, even with "special grease". Just use a little spit as lubricant. None of the housing manufacturer's make their own grease. They just like to sell these little pre-packaged tubes at substantial cost to the user.
    Edited by jcclink
  3. Dow Corning Molykote 3451 can be used on any O-ring safely.
    Dow Corning Molykote 1292 can also probably be used on all O-rings but is not listed as a recommendation for all. Others on this site have used it for all their O-rings.
    I have used both the Molykotes listed with several O=ring types will success, including Silicone and buna.
    You might a search on O-ring or perhaps grease at this website. Perhaps +O-ring +grease would be a good search as well. Using the plus signs will only show threads with both O-ring and grease present at this site.
    Dave
  4. Dow Corning Molykote 3451 can be used on any O-ring safely.
    Dave
    There are lots of threads about these new lubricants. I would personally avoid the 1292 since it is thickened with Polyurea. The 3451 is thickened with teflon so it should be OK. Look at
    http://wetpixel.com/forums/index.php?showtopic=27279
    for more info. Christolube and tribolube should also be safe for any oring.
    Bill
  5. [quote name='jcclink'
    If its black (buna-n) buy a tube of good quality silicone grease. None of the housing manufacturer's make their own grease. They just like to sell these little pre-packaged tubes at substantial cost to the user.
    good to know and what I would have thought
    just more $ for them
  6. But Ike does usually toss a tube or two in with almost ANY product: port extension, zoom ring, housing, etc. They also send them back with your housings after a repair and cleaning session. I just throw them into a ziplock once opened...because it is so thick, unless you pretty intently "squoosh" the tubes, they don't really tend to goo out much even inside the ziplock inside the gear bag.
    I think I'm up to like 10 backup tubes at this point, and the vast majority of my gear was bought used aside from one new port for the 7-14mm lens, and I did send the housing in for a cleaning/repair session.
  7. And it is a good reason to keep those last film containers :-), I keep them in those.
  8. If your set on the Ike grease, get a very small screw top make up jar from your female friend.
    Squeeze about 10 of the mini-Ike tubes into it .
  9. I keep my mini Ike-tube also in a small zip-locked plastick bag and nothing is coming out from the tube. Neither is the grease drying inside the tube.
    One tube has lasted more than a year, so personally I don't see any need to buy some extra silicone greases. I have also atleast 4-5 tubes for spare - so that's like 4 years stack :D
  10. Personally I love the little Ike packets, got loads.
    As they are small always have to hand and not a problem if lost.
    Also as they are nearly single use its dificult to contaminate.
    Wish I could get some Oxygen comparible ones so I could use on by rebreather.
    Richard B.
  11. Richard,
    What model rebreather do you dive?
    We have oxygen compatible grease in 5 gram single use packets.
    follow this link to view the packaging:
    www.aerospacelubricants.com/tribolube/scuba
    We will work something out via the manufacturer or a distributor close to you.
    Regards,
    David Lodwick
    Richard B.
