Hi Gang,
OK, so I've been shooting with a Canon 20D in Ikelite for 3 years now and learning underwater photography all the way, I've had some good results too (IMO), I'm a hobbyist with aspirations.
But times have changed, tech has moved on and airline restrictions have started to play a major part. I've not been thrilled with the Ike housing, but it does the job. I intended to upgrade to a 5D Mk2, new body new lenses new housing etc, lots of expense. But with airline bagage limitations being placed on us travelling in the Euro zone (US baggage limits are great in comparison), it's getting more difficult to sort the kit packing to stay within weight limits and transporting to dive sites can also be a pain.
The 5D2 setup is going to weigh alot as will any full-size DSLR setup, so I think my priorities have changed to find a lighter setup (I don't think any compact camera will cut the same mustard, no pun intended Alex
), and hey presto Olympus produce the E-620 !
So the question is, what benefits will I lose or gain, from moving from a FF/cropped sensor flagship quality camera system to a perceived consumer system.
My research shows that the results from members using the Olympus cameras and lenses are equally as good as (and possibly better than) any other system, so what am I missing here?
I like the idea that Olympus provides lower weight, lower cost, reduced size, top lenses, glass ports, simpler setup, strobes that are lighter weight and fully TTL (individually adjustable, INON) if I want. Apart from lower noise/higher ISO and depth beyond 40m, why would I want to move to FF or even stay with cropped in a more expensive housing??
I usually like to shoot all types of UW scenery, landscape, close focus WA, wrecks, macro, pelagics, will the Olympus serve me well in these areas?
What about handling in the water, I find the Ike viewfinder awkward to use, I've heard lots about live view but no-one seems to like it because of focus and shutter lag, what is the Olympus viewfinder like on the PT series housings? Other manufacturers produce extended viewfinders that seem to do a good job.
Thanks for your thoughts?
Tim
