10Bar HS-Cn-G10 underwater housing for Canon G 10 and Inon Fisheye UFL-165 AD
Started by Pedro ·
  1. It´s possible work with the 10Bar HS-Cn-G10 underwater housing for the Canon Powershot G10 and the Inon Fisheye UFL-165AD, with the addition of 10Bar ADF-M67 adapter?
    Some one have the underwater photographies takes with this equipment.
  2. This is a case of "yes" and "no".
    The comment on the other thread that the G9 and G10 lenses are unsuitable for W/A is total bunk.
    On the G9, one can use the INON UWL-100 and the dome port to get a very wide perspective ... I think about 130 degree FOV.
    With the G10, there is a new fisheye port for the FIX/Fisheye housing out soon that will give a 160 degree FOV.
    That said, the UFL-165AD isn't a great option as all the mounting options on the existing housings result in significant vignetting and require a big zoom to avoid ... kinda defeating the purpose.
    If you want true W/A with the G10, the FIX housing is the way to go right now ... there is a 15mm W/A Port that offers a 90 degree FOV and the upcoming fisheye port for 160 degree FOV.
  3. The comment on the other thread that the G9 and G10 lenses are unsuitable for W/A is total bunk.
    I agree - ordinary Wide Angle lenses (either Inon, Ikelite or similar) give great results with G9 - atleast as far as I have experienced.
    And just as You pointed out, Fix housing + Fix fisheye for G10 should be a really great combo! Sad that G9 and Ikelite hasn't got anything similar.
    Karel
  4. Sad that G9 and Ikelite hasn't got anything similar.
    The "G9 + Ikelite + Inon UWL-100" gives approximately the same perspective (after zooming to correct zignetting) as the "G10 + Ikelite + New Dome Attachment".
    http://www.ikelite.com/digicams/wideangle/g9angle.html
  5. The "G9 + Ikelite + Inon UWL-100" gives approximately the same perspective (after zooming to correct zignetting) as the "G10 + Ikelite + New Dome Attachment".
    wow. I didnt know that :P
    Thank for pointing that out!
    Karel
