Macro Mate?
Started by Fontaine ·
  • 10Posts
  • 10Replies
Macro Mate?
  1. Im reading backscatter and in its description of the macromate it only mentions that the macromate doubles the magnification with the canon and nikon 105mm lenses. What about the 60mm???? Surely it doubles the magnification of this lens as well, right?
    Does anyone have experience using the macromate with the 60mm lens, if so how did you like it?
    Fontaine
  2. Im reading backscatter and in its description of the macromate it only mentions that the macromate doubles the magnification with the canon and nikon 105mm lenses. What about the 60mm???? Surely it doubles the magnification of this lens as well, right?
    No, with the 60mm it'll increase magnification by only a factor of 1.4. Use the calculator at the bottom of this page to see how the effect of a 100mm closeup lens varies with the focal length of the primary lens.
    Les
    Edited by reefnet
  3. No, with the 60mm it'll increase magnification by only a factor of 1.4. Use the calculator at the bottom of this page to see how the effect of a 100mm closeup lens varies with the focal length of the primary lens.
    Les
    Right, so given the steep price I may as well just get a 2x TC.... would be nice to be able to switch between macro and super macro though
    i just checked the link out you sent and had never seen this company, its a significantly cheaper price then the macro mate, hmmmmmm
    Edited by HappyBubblz
  4. Right, so given the steep price I may as well just get a 2x TC.... would be nice to be able to switch between macro and super macro though
    You went to Les's site. There is a lot of discussion on the various possibilities of add on macro lenses here
    http://wetpixel.com/forums/index.php?showt...9&hl=subsee
    do take a look. I use a SubSee and it is a good lens, but depending on your lens/port it can be a bit soft in the corners.
    Bill
  5. You went to Les's site. There is a lot of discussion on the various possibilities of add on macro lenses here
    Bill
    Thanks Bill, that was very helpful, I did try doing a search but did not find that debate. I think I need to get a 100mm lens before I think about doing super macro with a wet diopter, Im leaning towards just getting a 2x TC as from what I understand TCs do not effect focal length.
    Fontaine
  6. Thanks Bill, that was very helpful, I did try doing a search but did not find that debate. I think I need to get a 100mm lens before I think about doing super macro with a wet diopter, Im leaning towards just getting a 2x TC as from what I understand TCs do not effect focal length.
    Fontaine
    Before investing in a supermacro tool, you should make sure it suits your needs. A good starting point would be to read the following series of articles:
    Les
  7. Before investing in a supermacro tool, you should make sure it suits your needs. A good starting point would be to read the following series of articles:
    Les
    Ive been reading that one, very informative...
    Ive just been to the camera store and they are telling me NO TC exists that fits onto the canon 60mm!!!! does anyone know if this is true, i cant believe it and think the guy must not know what hes talking about.
  8. He's correct. The 60 is an EF-S mount lens, while the teleconvertors on the market are designed for EF lenses.
  9. He's correct. The 60 is an EF-S mount lens, while the teleconvertors on the market are designed for EF lenses.
    Right so the 100mm must be an EF lens right?
    I think im going to forget about super macro for the moment and just concentrate on getting a WA setup and come back to SM when I can afford to get a 100mm lens.
