Small Subal dome
Started by Hamish Morrison ·
  • 21Posts
  • 21Replies
Small Subal dome
  1. I've been on the look out for a small (4") dome for my Subal & have come across a DP64b that is for sale. As these are not produced anymore can anyone tell me if it would be suitable for wide angle macro work? I seem to remember some mention of the DP54B recently. Is it similar, earlier / later version of the same thing?
    Hamish.
  2. I've been on the look out for a small (4") dome for my Subal & have come across a DP64b that is for sale. As these are not produced anymore can anyone tell me if it would be suitable for wide angle macro work? I seem to remember some mention of the DP54B recently. Is it similar, earlier / later version of the same thing?
    Hamish.
    Hamish
    I remember that the DP54B was a small diameter glass port used for the 20mm lens with a +4 diopter on film cameras - I used it with an F100. The DP64B was 10mm longer but used the same glass and from memory was for 24 and 28mm fixed focal length prime lenses. I used the DP54B for a long time with he 20mm f/2.8 AF lens. Corners were not bad but not perfect from memory, and again from memory focus was possible fairly close but corners softened eventually. Very compact ports though!
  3. Paul,
    So, by the sounds of things the extra 10mm extension might work in my favour if I was adding a teleconverter / tube to my FE?
    Hamish.
  4. I have a Subal DP54 which I use with the Tokina 35 mm macro lens. It works well with this.
    From previous attempts I believe this port will vignette with anything wider than 28 mm (35 mm slide film).
    Personally I would look for the small Wide angle port SWB or SWC and determine the correct ext ring. I recently picked one up cheap from the UW photo list site.
  5. Hi Dave, thanks for the real world advice. Buying sight unseen is always a worry & its easy to make an expensive mistake!
  6. Watch out for the change in port 'O' ring sizes!.
    You could get a mixed set and have a flood!
  7. Talking with reef photo, the 100 mm port comes with the larger 3 mm o-rings. In the 3rd and 4th generation mounts.
    If you keep the old, smaller 0-rings in the older ports they will still work fine with the 3 generation mounts. I do this all the time. Like you said, just don't mix them up.
  8. I am currently working with this port now with the 4th generation Subal mount. With the Tokina 10-17, you will need the 15mm extension ring as the 10-17's lens shade will strike the inside the dome when zooming in to 15 to 17 mm. Still trying to rap my brain around the idea of using such a tiny dome port.
  9. I have just been testing the Zen dome on FX and DX Nikons, with Nikon 16mm, Tokina 10-17mm and Sigma 15mm FE. The best combo is definitely DX + 10-17mm. On a Mk3 port Subal you do not need a port extension ring with the 10-17mm - in fact if you use one you will see the sides of port.
    Small domes have some positives and some negatives - mostly related to optics. Optical limitations of this dome are the same as others of similar specification.
    I will write up a more detailed review soon, but I would like to make some real world photos in addition to the pool tests. It is a complex issue.
    Edited by Alex_Mustard
  10. I am currently working with this port now with the 4th generation Subal mount. With the Tokina 10-17, you will need the 15mm extension ring as the 10-17's lens shade will strike the inside the dome when zooming in to 15 to 17 mm. Still trying to rap my brain around the idea of using such a tiny dome port.
    YOu use the lens shade inside the port? Never occurred to me. I've been shooting a Subal ND-30, D300, 10-17mm w/o the shade using a Zen Dome.
  11. .................. 10-17mm w/o the shade using a Zen Dome.
    How is the shade removed? I just had a quick play with my 10-17 and I couldn't get it to budge when I tried to screw it off (I didn't use a lot of force though as I was afraid of damaging it).
  12. Watch out for the change in port 'O' ring sizes!.
    Will the new larger O-rings work with the older ports like the DP54b?
  13. My 4" Zen dome arrived on Thursday and I got it wet for the first time today. I got it specifically to do "wide angle macro" with the 10-17 on a 1.4 teleconverter. I have tried WAM with my Subal 8" dome and really like the concept but the large diameter of the 8" dome creates problems with lighting subjects very close to the dome and makes it impossible to get a good angle on subjects on a flattish surface or on the bottom. The setup for today wasn't perfect, my 1.4X teleconverter is 20mm long and the only suitable extension I have is 18mm. As a result the lens was sitting too far forward in the dome and I could only zoom into 14mm before the lens hit the dome. Some of the shots look a little soft in the corners but I don't know if this is the nature of the beast or it is because the lens isn't sitting quite where it should in relation to the dome. Overall I'm very happy with the Zen dome (build quality and finish are excellent) and the results I got today and I can see it getting a lot of use in future.
  14. The setup for today wasn't perfect, my 1.4X teleconverter is 20mm long and the only suitable extension I have is 18mm. As a result the lens was sitting too far forward in the dome and I could only zoom into 14mm before the lens hit the dome. Some of the shots look a little soft in the corners but I don't know if this is the nature of the beast or it is because the lens isn't sitting quite where it should in relation to the dome. Overall I'm very happy with the Zen dome (build quality and finish are excellent) and the results I got today and I can see it getting a lot of use in future.
    While I am waiting on a zoom gear to use my 10-17 with a 1.4 teleconverter behind this port. Ryan recommends get the zen port as far out in front of the lens as possible before it starts vignette with the lens. I did some testing with a the lens/teleconverter combo with a 40mm extension ring and found no vignetting, athough I suspect a 33mm extension would work too.
  15. Ryan recommends get the zen port as far out in front of the lens as possible before it starts vignette with the lens.
    Is that just for when using it with a teleconverter or is it applicable to when using the 10-17 by itself?
    I have a 33mm extension and the day off tomorrow so I'll give it a run and report back in a day or two.
  16. I have a 33mm extension and the day off tomorrow so I'll give it a run and report back in a day or two.
    I tried the 10-17 with 1.4X teleconverter and the 33mm extension today and was very happy with the results, everything seems to be much sharper all around. I don't know whether this due to lens sitting back further from the port, the fact that I was actually able to shoot at 17mm and had a narrower field of view or a combination of both but I like it. :island: I wasn't able to take any shots at the 14mm I was limited to with the 18mm extension as I don't have a zoom gear for it (I'm not about to invest in the Subal version only a couple of weeks out from receiving my Nauticam 7D housing).
  17. I tried the 10-17 with 1.4X teleconverter and the 33mm extension today and was very happy with the results,
    Out of curiosity, what brand 1.4 TC are you guys using?
    Kenko announced today an upgraded
    MC4 AF 1.4X DGX converter with Gate Array IC (Integrated Circuitry).
    Or should I instead consider the more expensive Tokina or Sigma 1.4 converters for my Tok1017 and Sigma 15?
    Bo
  18. Gudge, thanks for the reporting on the results of your tests with the Zen. It certainly looks very promising. Did you ever get the shade off or was that not necessary in the end?
    Hamish.
  19. Out of curiosity, what brand 1.4 TC are you guys using?
    I'm using a Kenko 1.4X Teleplus Pro 300
    It wasn't necessary to remove it once I used the longer extension (and I didn't get any advice on how it came off :island: )
    Edited by Gudge
