poor eye sight and diving masks when using a camera
Started by wrb ·
  • 22Posts
  • 22Replies
  1. Hi I have noticed over the past couple of years that my close vision eye sight has deteriorated. I use bifocal lenses for reading on land and was wondering if anyone could suggest the best option underwater. My dilema is this: With a normal lens i can just about see my watch and computer on my wrist, the long distance vision is fine and I can still identify a healthy reef thankgoodness. When I use my housed camera I have great difficulty in seeing the controls or the picutres I have taken. can anybody who has experienced these problems please offer a solution. To my way of thnking I need lenses that allow me to fully operate my housed camera when close to my face, will allow me to read my watch at the end of my arm and enable me to continue to see the dive that I am participating in. All suggestions will be appreciated.
    Two years ago I brought a dive mask with a plastic eyeglass frame from ebay.
    Then,I ordered a "progressive lens" for the plastic eyeglass frame, and insert the frame into the tusa dive mask.
    The best underwater vision I ever have. Both my eye have surgery for retinal detachment and cateract.
    I can film and look at the video monitor and able to see far end of the object at the same time.
    Edited by edmond320
  3. I have one eye corrected by contact lens for near vision, and use different powers for diving, as opposed to "normal" life. A dive trip can be a month or two, so I switch lenses at the beginning of tghe trip, then back again at the end. This fine adjustment allows me to better see the really small macro stuff. Tried bifocal lenses in mask, as well as those gauge inserts, but they are reliant on you using the ower part of your field of vision. I find this creates eye strain, and suboptimal vision. Progressive presents similar problems. When using the camera, and for visual inspection of subject material, I find it much better to look dead on.
    If you've not tried this kind of "split vision", different corrections for each eye, it works much better than you might imagine. I always wear the one contact lens, and add extra correction as needed. For driving, movies, and such, I wear glasses with optimal correction for far vision. When using a computer, I frequently wear a pair of reading glasses, with a single lens to correct the one eye for near vision. With age, come vision problems. My approach works quite well for me.
  4. I use one day contact lenses (cheap if you loose one) to enhance my view far away.
    As i start to have difficulties to read near too, i will soon put this in my mask: http://www.optx2020.com/diveoptx.cfm
    I know a lot of divers using this inexpensive and simple solution and all are happy (as far as they can, having need of reading glasses...) with it.
    A better solution would be graduated lenses for your dive mask, but they are expensive, limit your choice of mask and
    may not be available as multi-focal glasses.
    Chris
  5. I use one day contact lenses (cheap if you loose one) to enhance my view far away.
    Chris
    I'm about to graduate to bifocals myself and hear good things about the stick on type such as the diveoptx...I wear a multi-focal contact but still have to use reading glasses top side and have a tough time reading my strobe settings UW....sooo I'll be buying a set soon too...only like $40 a pair at my local dive shop.
    Old age blows!
    Mike
  6. I had the same problems that you are describing.
    I found an "off the shelf" Seavision dive mask with diopters built into the lens at my LDS so I could finally read my gauges without any hindrances. They are more expensive than a regular dive mask but well worth it as far as I'm concerned. Price as I remember it was around $199.00 CAD for the mask and lenses with built-in diopters.
    Their website is located HERE.
    I also dive with an Oceanic Datamask and had a small magnifying lens professionally cemented into the lower portion of the mask by my optician. The lens works perfectly and it wasn't that expensive (about $80.00 CAD) to have done. I gave up on the stick-on diopters as I kept loosing them.
    You can also do a search on the topic here at Wetpixel as I recall several threads over the last few years with some excellent suggestions in them.
  7. I had the same problems that you are describing.
    I have used the Seavision dive mask called the "gauge reader" for several years. I wear contacts for diving and the gauge readers are great for seeing my camera controls. Don't forget to adjust the viewfinder diopter on your camera to work well with looking through the housing.
    I tried the stick on diopters before this mask and they just kept falling off.
  8. I used to wear contact lenses for distance correction, but in the past few years my near vision has been affected and I needed reading glasses. I tried the stick on lenses inside my mask but they kept falling off or fogging up.
    Then I found out that there is such a thing as multifocal contact lenses. They are like progressive lenses for eyeglasses, in that you have a near vision, middle vision and distance vision correction built in. It took a while to find a compatible brand, but I've been using them since last summer and they've been great! I can see my gauges when I'm diving, and I no longer need reading glasses to read tiny print above water. Check these out if you're already wearing contact lenses.
  9. I had the same problems that you are describing.
    I have tried the contacts lenses and glue-in lenses. Seavision is the best. I have a no line, multi focal with astigmatism correction mask.
    Bob
  10. Been using these folks for many years and have always been satisfied.
    http://prescriptiondivemasks.com/
    Just sent my Hollis M-1 to these folks this week. Have tried the diveoptix inserts with unsat success. Left lens kept coming loose even after repeated cleanings and installations. Talked to the folks at prescription dive masks and was sold. Very positive and informative. Great web site also. Be sure to check out their "how to dot your pupil" and "how to draw your bifocal line" on their website. My wife got a little carried away with the sharpie and felt it necessary to include my eye brows as well!
    Bob
  11. Prescriptiondivemasks.com is a fantastic company. I have conferred with Linda long and hard and came up with a "reader" mask where more than HALF of the lens is the "bifocal". I have excellent equipment reading without having to look through a little lens corrector. I still have good distance vision at the top half of the lens.
    I just got my second mask with the same configuration. Works GREAT!!
  12. Prescriptiondivemasks.com is a fantastic company. I have conferred with Linda long and hard and came up with a "reader" mask where more than HALF of the lens is the "bifocal". I have excellent equipment reading without having to look through a little lens corrector. I still have good distance vision at the top half of the lens.
  13. I'm lucky in that Prescriptiondivemasks.com is physically located about a mile from my house, in a little strip mall, next door to Baskin and Robbins.
    Any suggestions as to which brand / style of mask, or characteristics of a mask, work best for adding the "reader" capability. I know Prescriptiondivemasks.com sells masks (upon which to apply the "reader" capability). Should I buy one of their masks - or bring in my own? Which brand/style of mask have y'all had success with?
  14. Another vote for Prescriptiondivemasks.com, they are wonderful.
    I have the executive readers and use an Atomic Frameless Mask.
  15. I'm lucky in that Prescriptiondivemasks.com is physically located about a mile from my house, in a little strip mall, next door to Baskin and Robbins.
    If you're happy with the mask you have now, call them and ask if they can add the "reader" lens to your mask. That's what I did and they said "no problem".
    Bob
  16. Not sure where you are, but I know this mob post all over the world.
    http://www.ozbobscuba.com
    you simply give Rob your optical prescription, send him your mask, indicate where on the mask you want the lenses and he sends it right back.
    My photography improved quite literally with the first dive I did with them; I'm getting a second mask done in case I lose the first one. Can't dive without it now.
  17. I'm lucky in that Prescriptiondivemasks.com is physically located about a mile from my house, in a little strip mall, next door to Baskin and Robbins.
    You and I live fairly close to each other. I'm in La Mesa. Never buy a brand, of anything, whether it is a mask, a TV, a car. You always buy the 'model'. Find a mask that fits you well, is of low volume and feels comfortable. No matter whether it is Scuba Pro, Atomic or any other brand. If it feels good on you, if it fits properly, that is the one to get. Remember that a new mask will fog up on you so scrub the whole mask with either dishwashing soap, toothpaste or whatever works as long as it is non abrasive. Then clean it again...and again. Eventually the silicon spray that is sprayed over the entire mask will go away and you'll have clear vision made clearer by your lens.
  18. I have all kinds of problems with my eyes because I had an undiagonosed "lazy eye" when I was a youngster. It caused my right eye to become overly dominant and resulted in astigmatism in my left eye. This caused strain in my right eye, taking up the slack. I have a completely different prescription in my left eye to the one in my eye.
    Above water I wear varifocals, from the moment I wake up, to the moment I go to sleep.
    So, I guess I feel qualified to comment on this post.
    I used to wear contact lenses when I was diving and I hated them. They only corrected my near vision, made my distance vision worse and they stung, made my eyes water, all kinds of annoyances.
    Eventually, about 6 months ago, I decided to try a (cheap, just in case it didn't work) prescription lens mask.
    I visited my LDS http://sounddiving.co.uk/ and bought a new mask, identical to the one I already use, nothing special, in fact, a bit generic but, I like it. Steve sent it off to have the lenses fitted, two weeks later I was in the water with it.
    Total cost was about GB£130.
    It is, without a doubt, the best piece of dive gear I've EVER bought. It's revolutionised my enjoyment of my diving.
    I have a Simply Health https://www.simplyhealth.co.uk/sh/pages/homepage.jsp?source=ppc&cid=9703 private health plan through work that gives me a GB£200 allowance for prescription eye wear and dentistry and, after a little coaxing, they paid for the mask and the lenses.
    When my policy renews in January I'm going to have a verifocal version and keep my existing one as a spare.
    My advice, for what it's worth, would be: If you're thinking about it but hesitating don't, go do it. Don't get stick ons, don't wear contacts, go see your LDS and order a mask with fixed, corrected lenses, you won't regret it.
