Sony NEX-3 APS-C compact digital camera leaked
Started by echeng ·
  • 21Posts
  • 21Replies
  1. Details about Sony's upcoming NEX-3 APS-C rangefinder camera were leaked today by Digital Photography School. The new camera uses a Sony "E Series" lens mount and captures 14.2 megapixel images at 7 frames per second. APS-C-sized CMOS sensor. No details on video, but the specs do note that the camera will save videos in MP4.
    It's great to see the revival of large imaging areas in compact cameras; previous to the recent proliferation of APS-C-sized sensors in small cameras, it was virtually impossible to capture a high-quality image using a compact digital camera. Continue reading for full specs and photos of the NEX-3.
  2. That rear dial looks like a tilt, turn, and four-way press controller. Those often mean fewer underwater housings will be available, because of the complex linkages required.
    As for video, the rumors are that the NEX3 will do 720p video, while the NEX5 will do 1080p video. The NEX5 is also supposed to have more fps. It will be interesting to see the accuracy of the leaked specs when Sony makes the official announcement tomorrow.
    Edited by davelew
  3. That rear dial looks like a tilt, turn, and four-way press controller. Those often mean fewer underwater housings will be available, because of the complex linkages required.
    Be interesting to see how much market share these will take before Canon and Nikon come out with their own. If nothing else I'm sure third party lens adapters will be developed for these cameras.
    Bo
  4. These back-lit supposedly very sensitive new sensors sounds interesting. What do they actually promise in terms of nosie/sensitivity?
  5. Be interesting to see how much market share these will take before Canon and Nikon come out with their own. If nothing else I'm sure third party lens adapters will be developed for these cameras.
    Bo
    The rumors I here are a Nikon EVIL camera in the September/October 2010 timeframe.
    Canon seems to be trying to serve the same market with their S90 and G11 products, so they have less incentive to make an EVIL camera (Nikon making a product that eats into S90 and G11 sales is likely, Canon making a product that eats into S90 and G11 sales is less likely).
  6. According to my conversations with Canon, they are very interested in the mirrorless slr space and will have a product response.
  7. Regarding picture quality it looks way better than the current m4/3:
    http://daten-lager.net/files/file127356657...PL1-GF1-GH1.jpg
    (It is probably also better than the current sony/nikon aps-c)
    Not everybody thinks there's such a large difference in quality.
    from http://www.imaging-resource.com/PRODS/NEX5/NEX5A.HTM
    When we originally looked at the Sony NEX-5's high ISO images, we thought a new benchmark had been set. Indeed, the images do look pretty good, and may actually set a new high mark for overall quality, but these detail crops show that it's not quite a complete coup. The chief rivals for the top spot continue to be the T1i and E-P1 at ISO 100, and the E-P1 and T1i at ISO 3,200. At 3,200 the T1i renders more lines in the Lager letters, but that's partially a function of its slightly higher resolution (14.2 vs. 15.1). I'd say the Sony NEX-5 is probably the most even performer we've seen to date in this price and size range.
    Also consider that this test is not independent of lens quality, focus errors, and other variables, so again take this mostly as a comparison of what each camera was able to do with the best standardized optics we can muster. The Samsung NX10 used its very sharp 30mm f/2 lens. The Olympus E-P1 and Panasonic G2 used the rather excellent Olympus Digital Zuiko 50mm f/2 Macro lens. The Sony NEX-5, Nikon and Canon used our laboratory-standard Sigma 70mm f/2.8 EX DG Macro lenses, which are very sharp.
    The daten-lager images you link to show a huge difference in image quality at ISO3200. On the other hand, although imaging-resource likes the NEX-5 as among the top small cameras, they don't think there's a huge difference in image quality between the NEX-5 and some of the other top cameras.
    I think the last paragraph is important. The measured performance of the camera body depends on the lens that is being used for the test. The images that you linked show a much larger difference between camera bodies than the images at imaging-resource, even though imaging-resource seems to be a huge fan of the NEX5, so I wonder about the setup for the tests.
  8. Not everybody thinks there's such a large difference in quality.
    The difference might be not that big but even the examples of the imaging-resources confirmed for me that the sony NEX is better at high iso than the m4/3 cameras. However, the high iso performance is not that important for the UW-photography . I'm sure that these NEX cameras deliver superb quality results at base iso and the system provides enough quality even for professional applications. I agree with you that the lenses has a major impact and the NEX system still needs a good macro lens (panasonic has it). The fisheye and wide angle converter is interesting concept but I'm a bit worried about the image quality.
  9. Agree, adapters aside, it will be a lot more interesting when they release a few more lenses (e.g. a macro lens and a wide angle lens) since the adapter for current alpha series lenses does not support autofocus . . .
    Edited by MikeO
  10. Agree, adapters aside, it will be a lot more interesting when they release a few more lenses (e.g. a macro lens and a wide angle lens) since the adapter for current alpha series lenses does not support autofocus . . .
    They already have a wide angle lens and fisheye lens mount on top of the 16mm F2.8 lens
  11. That's one ugly camera.
  12. I just wish one of these cameras would have a built-in electronic viewfinder (not add-on), it's still my preferred way to compose an image.
    Just hoping Nikon will do this when they get around to their EVIL cameras. Maybe even a built in flash that will work in commander mode with the Speedlight system.
    I just want a Leica M9 at Japanese camera prices and with a few modern amenities like autofocus.
  13. I thought the Sony 707 was ugly as well.
  14. I've just checked the homepage of ikelite and they are considering to make a housing for the NEX cameras. No further details yet.
    I think they will make a standard housing body shell that can accommodate both NEX and MFT cameras using the same port system.
  15. "Rumors" at Long Beach Scuba Show indicated that Sony "may" be working on an UW housing for this camera. I sure hope it's true because NEX-5 with the 16mm (24mm) pancake will be an excellent setup for family scuba trips.
    (edited to inline video -mod)
    Edited by echeng
  16. Don't know if the shutter act speed of nex-5 is close to DSLR.
    From the introduction, it remove the reflector to reduce the size.
    Maybe it means the shutter react speed slow down a bit as well....
  17. Tried it today. It's tiny, fast and works in low light. It's also cheap (700 CAN).
    If they make a SMALL casing I'm tossing the G10 and the Oly 520 which feel like dinosaures now :)
    Edited by renep
