7D Hugyfot Housing
Started by SimonSpear ·
  • 25Posts
  • 25Replies
7D Hugyfot Housing
  1. I just wanted to emphasise a few things before anyone reads on. I have very little prior experience using SLR housings. This review is purely for VIDEO use and not for shooting stills. The housing was not a review or pre-production version, it was the full retail product. It is certainly not an exhaustive review, but more a collection of my thoughts and observations after using the camera and housing for a month in Spain during June/July. I actually almost decided not to write this at all until I’d had a chance to use the housing again in September, but you’ll have to read on to find out why.... The only other teaser I’ll give at this stage is that in my opinion the much flaunted stability issues of using an SLR underwater for video could very well be a myth.
    Hugyfot First Impressions
    Hugyfot are renowned for producing well made and above all compact SLR housings. One of the biggest drawbacks shooting video is that if you want to use a really good (pro) camera you generally have to go large. With the luggage restrictions on airlines these days size matters more than ever before and with video you can often use up or exceed your entire luggage allowance with just the weight from your housing, let alone the camera itself, dive gear or god forbid a couple of shirts and a pair of trunks! It’s so bad that I’ve actually found that with the higher luggage allowances you get it can often be cheaper to fly business class than it can be to pay all the excess luggage charges flying in economy! So the thought that you can take a compact SLR housing like the Hugyfot and shoot great quality video is a very attractive proposition for the traveling videographer.
    When you first see and hold the 7D Hugyfot housing you know you’ve got something that is going to last a long time. Machined from a solid block of aluminum it feels reassuringly sturdy holding it, much like any of the top quality video housings do. The other thing you notice is that there really is very little space inside the housing. Hugyfot use the marketing slogan ‘fits your camera like a glove’ and you can certainly see why they say that.
    When you look at the outside of the Hugyfot housing you will notice straight away that it does not use snap ‘clips’ to close the housing like virtually every other manufacturer uses, instead they use an allen key solution. There is a very strong positive in this method being that once the housing is closed it is absolutely closed and there is no way it could be accidentally opened. The negative is obviously that you can’t open it up quickly if you need to. After god knows how many hundred dives diving with cameras I’ve never accidentally knocked or opened a snap clip or ever heard of it happening, so I’m not sure if that is a real fear or even if it has actually ever happened to anyone. I’m certainly in the once a housing is sealed its sealed camp, but as much as I hate to there are times when its very convenient to just to open up the back of a housing, make an adjustment and then close it up again. You can’t do this with the Hugfot.
    Assembly
    Whenever I get a new housing it can often take hours to understand how it all works and fits together. This was no different and at times I became really frustrated with just how tight it was inside the housing which of course is a direct consequence of its compactness.
    Now as I mentioned earlier I have very little experience with SLR housings, although in the past I have used and assembled polycarbonate SLR housings. Despite this I was not prepared to discover that if I wanted to use the zoom controls on the lens then whenever I put the 7D into the housing I would have to remove the lens first. I really hate removing SLR lenses and to be honest I’m pretty anal about how I go about it always making sure the camera is pointing down and the lens caps are to hand etc etc. Trying to put the lens on upside down with the camera inside the housing while at the same time making sure that the zoom grooves were aligned on the lens turned out to be a pretty impossible exercise. I tried and tried and tried, but even with practise it would still take 4 or 5 attempts to get it right.
    The solution is to sit the housing on its back with the camera sensor up and open and put the lens on that way, but with my anal tendancies it was pure hell to go through that every time. In an attempt to avoid possible sensor damage (my 7D had been back to Canon twice before this with sensor problems) I tried to use the camera without the lens gearing and the lens set to maximum wide angle, but by the time I was in the water the housing had been inevitably jogged around a fair bit and the lens had moved to a different position than I’d set it. So you are basically left with two options. 1. Put up with the lens off lens on scenario every time you want to put the camera in or take the camera out of the housing, or 2. Go out and buy some prime lenses. Option 2 isn’t necessarily a bad option, but it is an additional expense that many would not realise they would need to pay and obviously takes away the flexibility of a zoom lens.
    Another major disappointment is that although you can remove and replace the camera’s CF card by just removing the back of the housing you can not replace the battery without removing the camera entirely from the housing. For still shooters this is probably a moot point as battery life on the 7D is outstanding, however if you have liveview on all the time as you do when you are shooting video the battery does not last anywhere near as long as you’d like it to. This combined with the issues of removing the camera from the housing with lenses attached was another major annoyance for me.
    After a fair bit of negativity above we now move onto something really positive! All Hugyfot housings are now shipped with a ‘Hugycheck’ system installed to check how watertight the seals on the housing are once it closes. After the camera has been put into the housing and the lens and port is on you connect the Hugycheck device which creates a vacumn inside the housing. Once the housing has been de-pressurised enough an LED turns from flashing red to constant green and as long as it stays green your housing is watertight. As a test I used the Hugycheck on a sealed housing and 7 days later the LED was still green. Its a simple procedure, takes 30 seconds and gives you great peace of mind when diving that you are secure and safe from a very expensive flood!
    Controls
    Through a combination of push button, dials and triggers the Hugfot 7D housing gives you access to every control on the 7D. Being a compact housing it is also possible to get to most of these controls easily and quickly and with a bit of practise fairly intuitively. Comparing the 7D’s controls to the access you get on a housing with electronic fingertip controls is obviously unfair, but overall it is not too dissimilar than what you would expect to find on many manual control video housings.
    After using the housing for the first time in the water I found that the most essential control function of all for video wasn’t working properly. The record on/off leaver would not engage with the switch on the camera properly and often it would not even work at all. Basically the rubber shoe on the end of the metal leaver was loose and after it had been engaged a few times it would move out of the tolerance range of the control and then not engage the switch. My only solution to this in the field was to pack a small piece of card into the rubber shoe which helped it to not slip as much. This hotfix did not solve the problem, but it allowed it to last longer and sometimes it would even last all day. The drawback was that there was additional pressure on the camera control which would sometimes engage the record function even though you hadn’t touched the housing control itself. It also would STOP recording on occasion which was incredibly frustrating and resulted in lots of missed or incomplete shots. I informed my supplier back in the UK of this problem via email on the second day of diving, but no solutions were presented on how to get this problem fixed. I basically had to put up with it until I returned home and got to grips with the problem then (more on that later).
    I was really annoyed about this situation, which to me showed serious quality control issues as the housing should never have been sent out like that. Occasionally things go wrong and you have to accept that, but this was entirely avoidable. I’ve been in some sticky situations in the past while stuck in remote locations with things going wrong on equipment and had superb feedback and solutions presented to me by the manufacturers and suppliers. In this instance I was in the heart of Europe and in my opinion got very little support in the field from the manufacturer and supplier. I’m not sure if this is a difference in approach between a stills and video supplier, but I was not impressed at all.
    In the water
    Ok now to the fun part. I was in Spain to do some shooting for a client in addition to filming stock footage for myself both in the pool and in the sea. My client really liked some of the overcranking examples that I’d shown them on the 7D and wanted to use that wherever possible, but I’d also taken my trusty V1 and Gates Housing in case anything went wrong (although from my own experience I’ve found it very difficult to match HDV and HDSLR footage in post).
    My first 10 days was mainly pool work and topside shooting. The pool work with the 7D turned out to be a nightmare with the constant record on/off control problems as I’ve ready detailed above. However if I discount those problems then I actually found the 7D to be good, bordering on great to use in the water.
    With a dome port attached the housing is slightly negative but the port is significantly more buoyant than the rest of the housing and will rotate towards the surface if you let go. Like many I’d heard repeated references to ‘stability issues’ with the SLR’s that are now being used to shoot video underwater. I’ve actually had my fair share of stability issues shooting with it above water, but once it is below the surface I just didn’t come across them at all. Sure the housing was not perfectly balanced for shooting video, but I found it no more or less so than any number of the video housings out there for the smaller consumer camcorders. My own theory on the stability issues is that most of the first video recorded on these SLR housings was mainly shot by photographers who are not used to keeping a housing steady in the same way that video shooters are. No disrespect to them but keeping a housing steady for 24-30 frames a second for maybe 10 seconds or more is an entirely different skill than keeping it steady enough for two or three still shots over that same period.
    Although I didn’t end up doing as much actual diving as I intended to do I did managed to get down to the Cabo de Palos Marine Reserve for four days diving. The Med used to be such a rich ecosystem that it is bordering on criminal what has happened to it, however there are still pockets where you can get a glimpse of what life used to be like here and this area is one of them (despite encountering a discarded trawl net smothered over one of the reefs within the Marine Park). There were lots of Bass around, Moray Eels, Octopus, the local Groupers were out in force with sometimes as many as 20 spotted on a dive, schools of Barracuda were seen and even Eagle Rays and Sun Fish. The water was unseasonably cold at 15C as when I’d dived in this area before at this time of year it had been 18-20C! Everyone I spoke to was a little bemused about this change, but if you travel enough you notice that things are on the change more or less everywhere you go so it is not an uncommon story to hear these days.
    I was using mainly the Canon EF-S 10-22mm lens, but I also used the Canon EF-S 15-85mm and Canon EF 50mm f1.8. I found the 10-22mm to be the most to my liking if I had the zoom mechanism attached, but without it on I found the 10mm end a little too wide for general shooting. At f3.5 the 10-22mm it is ok(ish) in low light, but you do wish you had a couple more stops in the lens as you get a bit deeper and it gets a bit darker. I never went above ISO640 and normally limited it to 320 as personally I find the 7D to be too noisy for my liking above this.
    I was diving without lights so for filters I used a Magic Filter which I wasn’t entirely happy with. I’ve used Magic Filters before for video and found that you struggle to one touch WB with them below 10m (compared to 30m on the same dive with a URPRO filter). In fairness they were not designed to be used for video and they don’t claim to work that well below 10m, so they are not doing anything less than they say they do. I didn’t have a URPRO filter of the right size available at the time, but I’m planning to use them on my next trip in September and I hope to get significantly better results.
    One of the issues I thought I would have was focusing, but I found that if I focused in the mid range and used F10 or higher then the depth of field was large enough to keep a good amount of any shot in focus. For example I was able to keep a swimmer in focus to an acceptable level for the entire length of a 18m pool. I was happy with that but obviously it didn’t work so well the deeper you went, however it was still far better than I’d imagined it would be.
    Overall Opinion
    I really wanted to like this housing and in many ways I did, but overall it was let down by too many faults and it ultimately ended up being a frustrating experience using it. For pool work I could live with the shortcomings, but in four days of diving I never once managed to use the 7D for the entire day. Either the record control would stop working or the battery would run down and neither of those were fixable while bobbing around on a RIB out at sea.
    Once I was back in the UK I had a long chat with my supplier who in turn had a long chat with Hugyfot. Between them they listened to what I had to say and attempted to address my concerns. Being able to put the camera in and out of the housing without taking the lens off while using the lens zoom gear is never going to happen. Similarly there is never going to be a way to replace the battery without removing the camera. They did however test the record on/off control until they were able to repeat the fault that I experienced and as a result that control has now been redesigned. This housing was designed to be used for shooting stills and a hairy grouchy video guy coming along and finding lots of things that were not to his liking appeared to be a genuine surprise to them. It’s a shame as with just a little more thought and planning in the design stages this housing could have gone from a C to a B+ relatively easily.
    I’m going to be taking the 7D and Hugyfot to the Red Sea in September to try it out again in nice blue water and I’ll report back as and when I get chance to jot down my thoughts after that.
    Edited by SimonSpear
  2. Excellent review Simon... Very informative and not just a butt kissing piece like many articles :D Personally Im staying away from DSLR's for now as they are not that impressive ...
    Dive safe
    DeanB
  3. thanks Simon, out of interest what is the RRP on the Hugyfot housing?
    A good honest review, glad to hear about the stability issues too.
  4. Excellent review Simon... Very informative and not just a butt kissing piece like many articles :D Personally Im staying away from DSLR's for now as they are not that impressive ...
    Dive safe
    DeanB
    Hello,
    I'm sorry but a 7D in a Nauticam housing is very impressive, and I'm sure I'm not the only one to think so despite my obvious biases!!
  5. Hi guys
    Dean, I've actually been won over by the 7D while using it for video but it does have flaws and it is not, I repeat not a camcorder. When reviewing footage side by side in most situations it kicks the butt of HDV (not all the time) and in most circumstances it is comparable to XDCAM EX for a third of the price. Most people in the know compare it to using a film camera, but apart from my Dad's old 8mm cine when I was 5 or 6 I've not really got much experience of that! I think someone on here (could have been Drew) summed it up nicely once when he said that the current bread of HD SLR's are like a really, really hot girlfriend who has serious personality flaws :D
    Jon the RRP of the housing with a WA dome port comes in at around €3000.00.
    Alsky are you talking about the 7D+Nauticam for VIDEO? If so I'm sure that we would all be interested to read a full review on that from an experienced video shooter if you can point us in the right direction. If not then let me have a housing and I'll give it a really thorough testing and post the results here :)
    Cheers, Simon
  6. Hi SImon,
    Peter Rowlands used mine in the Red Sea with the Nauticam White Balance Port for filming video, I believe a review wil be coming in the next UWP magazine.
    A
    Edited by Alsky72
  7. it is comparable to XDCAM EX.
    Cheers, Simon
    Not what I've heard from users of both. I have heard its better than HDV however falls a little short of the quality of HDCAM EX and then that grows when you add Nanoflash ... Although the 5D is meant to be a lot better and a cheaper option... Everyone has different views I suppose :D
    Dive safe
    DeanB
    Edited by DeanB
  8. I think someone on here (could have been Drew) summed it up nicely once when he said that the current bread of HD SLR's are like a really, really hot girlfriend who has serious personality flaws :D
    Yes I did say that and I feel it was too misogynistic. It could also be a hot boyfriend with destructive and abusive streak (Stieg Larson style :)) as well.
  9. I have just reread my posting here above and, whilst what I thought after a couple of glasses of wine last night to be an innocuous comment, in the light of day looks like blatant commercialism. For that I apologise and will be more mindful of commercial sensitivities in the future.
    I do stand by my comments though but promise to restrict my enthusiasm to more appropriate fora if any offense is caused.
    All good wishes
    Edited by Alsky72
  10. Thanks for the link Alsky. That sure is a cracking opening shot! I'm not sure if I like the fisheye of the Tokina for video but on as positive note the footage was nice and steady and looked similar to the stability I was experiencing with the Hugyfot, so another good example to dispel the HD SLR stability issue myth. As for the overt commercialism well I did think it was in poor taste to hyjack a competitors review, but at least you had the balls to apologise once you realised what you'd done.
    Deano horses for courses my friend. I've no doubt that the EX1 is a better camcorder and XDCAM EX is way less compressed even without the Nano. However you can get a 7D plus a housing underwater for less than you can buy an EX1, so they are in very different price ranges. I've seen footage from an EX1 and 7D side by side and I couldn't tell you which shot was from which camera as they were so close in quality, so yes they are comparable, but they are not the same and the 7D because of the h264 compression is certainly not as good in post even after it has been converted to ProRes. Like I said the 7D has its flaws, while the EX1 doesn't really have any, or certainly not as many that's for sure!
  11. Deano horses for courses my friend. I've no doubt that the EX1 is a better camcorder and XDCAM EX is way less compressed even without the Nano. However you can get a 7D plus a housing underwater for less than you can buy an EX1, so they are in very different price ranges. I've seen footage from an EX1 and 7D side by side and I couldn't tell you which shot was from which camera as they were so close in quality, so yes they are comparable, but they are not the same and the 7D because of the h264 compression is certainly not as good in post even after it has been converted to ProRes. Like I said the 7D has its flaws, while the EX1 doesn't really have any, or certainly not as many that's for sure!
    He's just so easy :crazy::o
    Dive safe
    Dean(wind-up)B
  12. He's just so easy :crazy::o
    Dive safe
    Dean(wind-up)B
    Bah you'd think with a newborn that you'd have less time on your hands!! :)
  13. Bah you'd think with a newborn that you'd have less time on your hands!! :)
    :o:crazy:
    Dive safe
    DeanB
  14. Hi everyone,
    As the Supplier who provided Simon with his housing, I just wanted to make a couple of points about his review.
    We absolutely didn’t intend to leave you high and dry when you were in the field and having troubles with the on/off button. We pride ourselves on our customer service and it was a only missing communication (the last email you sent genuinely never made it to us) that meant we didn’t work with you to sort the problem out there and then. As soon as we had contact from you upon your return to the UK, I immediately drove down to London to meet with you, talk things through and fix the issue with your on/off button.
    The 7D housing has been Hugyfot’s best selling housing to date and this problem with the on/off button has occurred on a handful of housings. In these cases, it has been possible to rectify the problem with a small tweak to the existing mechanism.
    Finally, whilst we’re in the business of posting videos created using different camera/housing combinations, I just wanted to post this one that many of you may already have seen. It was filmed by Guillaume Nery’s partner, July Gaultier, using a 5D MkII in a Hugyfot housing and has already had over 5.6 million hits on YouTube. It’s an artistic interpretation of a ‘base jump’ into Dean’s Blue Hole and is visually stunning:
    Thanks for reading and happy diving :crazy:
    Andy
    DiveLife
    www.divelife.co.uk
    Edited by Drew
  15. Hi Andy and welcome to finally making it onto Wetpixel!
    Yes you did drive down to talk about my concerns once I got home which was appreciated and I probably should have made clearer in the review.
    As for the video - WOW. You've got to take your hats off to those freedivers. Very, very impressive work.
    Cheers, Simon
  16. Haha, thanks Simon. It does make for stunning viewing hey?! I have to say that there's more than enough for me to think about down there without having to worry about when to return to the surface for my next breath! I'd probably be so focused (no pun intended) on my camera settings that I'd forget...... :crazy:
  17. Yes you did drive down to talk about my concerns once I got home which was appreciated and I probably should have made clearer in the review.
    Cheers, Simon
    DAMN!!! If only you'd have made that clearer Simon I would have continued with my order for 5 Hugyfot housings ... Oh well :crazy:
    Dive safe
    DeanB
  18. I would have continued with my order for 5 Hugyfot housings ... Oh well :o
    Yeah kind of rought that you cut back to 3 housings :crazy:
  19. He's gonna dump that EX and move over to the darkside Drew, just you wait and see... :crazy:
    Cheers, Simon
  20. He's gonna dump that EX and move over to the darkside Drew, just you wait and see... :crazy:
    Cheers, Simon
    Next you are going to tell me Wagsy will buy a Mac :) But I will welcome them both with open arms when they come to the good guys side :o
