Results from the new TTL slave sensor from Ikelite...
Started by NLAVD ·
  • 25Posts
  • 25Replies
  1. posted on 6-13-2002 at 12:41 AM
    Day II with the remote sensor, I even played with the preflash option in the sensor, results not effected. Still shoots a full load..
  2. Shoot it on A
    Dial up the stop to the max (f9 or so)
    Go to speedlite options - variable power. Set power to -1 or -1.5
    Start shooting.
    Also, this might help you:
    www.reefpix.org/iketest/
    Good luck!
    James Wiseman
  3. Great..That helped!
  4. Well, looks like the CP5000, as well as the G2, both insist that if you want to manually set the aperture and shutter, then by damn you must want a full dump, and no option to still do TTL.
    Dumb damn design decision!
    For the G2, it is documented in the manual.
  5. I can't say it's the camera, I don't have the problem when I use the cord. (only with the remote sensor)
