Z240 o-rings want to pop out when screwing the cover back down
Started by Will_Clark ·
  • 23Posts
  • 23Replies
  1. There is no reason to use any o-ring other than buna/neoprene (the black ones) for our underwater applications. The colored ones just cause all these grease issues. like different grease for different colored o-rings. and do not provide a better seal. There is not a good engineering reason for complicating this issue. Change all your o-rings to buna & use a good quality silicone grease. One grease for everything. Don't make life more complicated than necessary.
    If you think you must use silicone o-rings (the orange/red ones) for some reason, DO NOT grease them. Spit works just fine as a lubricant.
    And don't play with your o-rings unless required. Depending on water conditions you could go for days without touching them.
    Edited by jcclink
  2. Light coloured o-rings make it much easier to see grit and dirt on them, rather than black on black on black;)
    Edited by londonsean69
  3. Light coloured o-rings make it much easier to see grit and dirt on them, rather than black on black on black;)
    Agreed, which I'm sure is why Inon use them in combination with the transparent cap.
    Jim.
