Any Panasonic Lumix 7-14 Users?
Started by kris ·
  • 26Posts
  • 26Replies
  1. Hello All,
    I am using an AG-AF100 and new to underwater video. Given
    the fact that I have to use Lumix lenses to take advantage of
    the automatic focus, zoom and iris, I am thinking about the
    Panasonic Lumix 7-14 lens. In going over other posts, it seems
    that a 7-14 is the most recommended for underwater shooting.
    Any thoughts on this subject and/or stories from Lumix 7-14 users?
    Thank you,
    Kris
  2. You should opted for the DMC-GH2:
    Lots of different lenses demoed by this you tube user.
  3. Thanks Espen,
    It actually still is an option. I needed the AF100 for terrestrial shooting,
    but I'm seeing that the GH2 is a great option for the underwater work.
    I watched the youtube video you sent and it looks great. I do have 2
    questions for you:
    1. Would the shot be less shaky with a larger housing? (Specifically one made for an AF100)
    2. Were you using a Lumix 7-14? If not, what lens and how do you run with full mechanical controls?
    All the Best,
    Kris
  4. 1. Would the shot be less shaky with a larger housing? (Specifically one made for an AF100)
    Hi Kris,
    There are only two housings available for the GH2:
    10Bar
    Diveross
    The latter, probably is the best: full alu body and depth rated to 100m. The Nauticam uses just Lumix lenses with different port. I emailed Nauticam and it's not possible at the moment to use mechanical lenses as the samyang or other cheap ones. Each port is specifically designed for a given lens. Maybe they are able to build some custom gear and port on request.
    There is also the seatool housing but except the sheet on their web site I never saw a working housing or a shot online.
    Bye
  5. I shot the 7-14 in the Nauticam housing and I think it suffers for the same problem as many rectilinear lenses do; unsharp corners, particularly for CF/WA. It still shot pretty well for other types of shots, but you have to stop down to f/11 at least.
    Personally, I think the 8mm FE is much better and sharper.
    This was taken with the 7-14.
    Jack
    Edited by JackConnick
  6. I use 7-14mm with EPL-1 in 10bar w/ semidome port - indeed unsharp and soft edge at 7- 8 mm
    here is example shot in good viz. 13-15m depth.
    [vimeohd]29965696[/vimeohd]
  7. I shot the 7-14 in the Nauticam housing and I think it suffers for the same problem as many rectilinear lenses do; unsharp corners, particularly for CF/WA. It still shot pretty well for other types of shots, but you have to stop down to f/11 at least.
    Jack
    I've used the 7-14mm for about two years underwater (first with hacked GH1 now with hacked GH2) for all my wide work and absolutely love this lens.
    I was puzzled to recently read comments about it not being sharp since I've been very happy with my results. After a few comparative tests (converted Subal F4 housing+ Subal glass dome vs Nauticam GH2 + Nauticam dome port) I'm starting to think that it's uw optical performance depends considerably on the dome port used. It's MUCH better with a larger diameter dome port.
    In fact now that I've become aware of the different performance I've delegated the Nauticam to macro work only. :)
  8. I've used the 7-14mm for about two years underwater (first with hacked GH1 now with hacked GH2) for all my wide work and absolutely love this lens.
    In fact now that I've become aware of the different performance I've delegated the Nauticam to macro work only. smile.png
    Hi George,
    On SB there is a thread in which they complain about being soft in a nauticam setup (gx1 + 6" dome). A user says that the lens is misplaced inside the port...
    Here the thread:
    http://www.scubaboard.com/forums/panasonic-planet/413982-panasonic-7-14-mm-4.html
    I linked page 4 where discussion became hot :)
  9. I use 7-14mm with EPL-1 in 10bar w/ semidome port - indeed unsharp and soft edge at 7- 8 mm
    Hi Mamel,
    Actually form that shot is impossible to evalute the lens. You never stop panning and at 24/30p at that speed you get alot of blur just for the quick movement.
    Bye
  10. I am eyeing the GH2 + Nauticam combo and have been looking at the 7-14mm vs 8mm options. The 8mm is great for shooting WA but coming from video sometimes I want to zoom in to get closer shots of something large like a broadclub cuttlefish, grouper, shark etc.
    Can the 7-14mm do that satisfactorily? Do you have a sample of a large subject zoomed in at 14mm? What about using magic filter on the 7-14mm, can it be stuck to the lens?
  11. What about using magic filter on the 7-14mm, can it be stuck to the lens?
    The lens doesn' accept front filters nor have a rear filter holder like the 8mm.
    If you want to use magic filter you should find some home made soluton...
    Bye
  12. I shoot this lens in a Nauticam with a GX1.
    Seems sharp to me.
    Maybe camera distance placement has been improved with the GX1?
  13. I think that user barked up the wrong tree. He has a GX1.
    Other people in that thread are saying that this lens and dome port combination is like other rectilinear lens with such a wide angle of view.
  14. Hi George,
    Here the thread:
    http://www.scubaboar...-7-14-mm-4.html
    Thanks for pointing that out Davide...certainly very interesting reading! :)
  15. Magic filter can be fixed to the rear of the lens. I attached it with some cellatape in June and it's still there now. Easy.
  16. I was puzzled to recently read comments about it not being sharp since I've been very happy with my results. After a few comparative tests (converted Subal F4 housing+ Subal glass dome vs Nauticam GH2 + Nauticam dome port) I'm starting to think that it's uw optical performance depends considerably on the dome port used. It's MUCH better with a larger diameter dome port.
    It is probably useful to differentiate between soft corners and other optical aberrations.
    George, if this statement is related to corner sharpness it is a curious one. DP-FE (and 2, 3, 4) is thicker and has a smaller radius of curvature than the acrylic optic Nauticam uses for the 7-14 port. Assuming the same placement, these factors would result in softer corners.
    I think 7-14 can perform quite well if you are careful to shoot an f-stop of around f11. I like the lens for blue water subjects, but would choose a fisheye for most close focus wide angle on a reef.
    Keep in mind that there are few (or no?) 35mm equivalent 14mm lenses that have a good reputation for underwater photography (except possibly Sigma 8-16 on DX). Zooming to 8 or 9mm makes a big difference if shooting more open f-stops with subjects in the corners.
  17. Keep in mind that there are few (or no?) 35mm equivalent 14mm lenses that have a good reputation for underwater photography (except possibly Sigma 8-16 on DX). Zooming to 8 or 9mm makes a big difference if shooting more open f-stops with subjects in the corners.
    always speaking of video here...
    I'm looking for a less extreme lens for deep wreck diving. 8mm fisheye is wonderful to catch the whole ship and the dramatic atmosphere but is a pita on details or inner spaces where, to cover the entire aov, you have to place your lights with surgical precision. We have only two viable options: lumix 7-14 or oly 9-18.
    I never saw a uw video shot with the latter.
    Going narrow (84 degrees) there is the wonderful Oly 12mm f2 but maybe it's too narrow.
  18. It is probably useful to differentiate between soft corners and other optical aberrations.
    Not so. The 7-14mm Nauticam dome is 6 inches...the Subal FE3 is an 8 inch dome.
    I do remember reading a good pool test done by another Wetpixel member of the IQ resulting from larger domes vs smaller, aggressive curvature domes. The larger domes gave what to me seemed a better optical result. I've found the same in my own tests of the several types of Subal domes that I have...including a new very aggressive "compact fisheye" port (FE100) that I bought to try with my favourite UW lens, the old Minolta 7.5mm MD.
    There are many optical/physical factors that operate...indeed interact...in complex ways as the diameter of the dome glass changes; i.e nodal placement, virtual image(s) proximity, peripheral distortions, etc.
    As far as I'm concerned the bigger the dome's diameter the better the optical performance.
    The merits or otherwise of the Nauticam domes is all a bit irrelevant to me now...I've sold my Nauticam GH2 housing in anticipation of the new GH3 which should be announced in a few days time. What little information there is about the GH3 suggests it should be a superb camera...even without a hack (i.e. H.264 @ 70 mbps I-frame out of the box). It will be weather sealed and have a larger pro quality body...hence will not fit the current Nauticam GH2 housing. smile.png
    Edited by HDVdiver
