Red Scarlet-X
Started by Drew ·
  • 174Posts
  • 174Replies
Red Scarlet-X
  1. I'd bet that Gates are hoping that the Scarlet will fit into the EPIC housing. It would certainly save a fortune on development costs that's for sure.
    Cheers, Simon
  2. Done mine ordered as well with a Red mote, I actually thought it was the same body as Epic due to all accessories for Epic being interchangeable with Scarlet, so fingers crossed re a housing, but I have a guy here in Oz who is doing something pretty cool with housings so there could be a few options.
    If it doesn't overheat. :) Imean if the 7D and 5D2 overheat, what chance does the Scarlet have of being cooler?
    My personal preference is to get a custom housing so I can fit a Ki Pro Mini or Atomos Samurai in there. Then one can do everything in Pro Res proxy then convert from R3D later. R3D requires Red Rocket to transcode otherwise it's a looooonnnnnggggggg process even on 12 core computers!
    Just saw a test with the Samurai and and Epic, and it worked like a treat.
  3. Done mine ordered as well with a Red mote, I actually thought it was the same body as Epic due to all accessories for Epic being interchangeable with Scarlet, so fingers crossed re a housing, but I have a guy here in Oz who is doing something pretty cool with housings so there could be a few options.
    Hey Jonny
    Is there footage of that test some where online or did you see it first hand.
    Mark
  4. Sorry wasn't mine, it was being used on a TVC, but it looked good.
  5. 1: Can the Atmos Samurai use the SDI Flag to start & stop recording? i.e. start recording when the camera starts to record. Record signal transmitted via the SDI interface
    2: Can it also accept external time code?
  6. Mark
    Yes, there is a SDI Trigger. It's also Genlock capable. It's even got lanc capability which gives more options for housings.
  7. LOL when RED said they were bringing a Bazooka to a knife fight for once they really were not exaggerating! Makes the Canon announcement look rather lame...
    Canon announced something??
  8. I think he's being sarastic Nick. :B):
  9. I'm a bit worried that Gates had no announcement of a housing for Scarlet. You would have thought given all the hype leading up the Scarlet announcement that *IF* gates had a housing for it they would have been shouting from the rooftops about it.
    Anyone have a link to the gates Epic housing because i can see no reference to it on the Gates webs site.
    It would so cruel if Scarlet gets no housing!
    J.D
  10. John
    I think you'll be pretty safe. If Gates makes one for the Epic, I can't see why they wouldn't do so for the similarly sized Scarlet, which uses the same Redmote etc. I remember they were talking orders for Deep Epic (if my memory doesn't fail me) a few months ago.
  11. John
    I don't see any reference to a deep epic on the gates site. Is there anything on the web anywhere about the epic housing from Gates?
    I've been waiting for Scarlet for a loooong time now - now its finally here and no mention of an housing from any manufacturer. I sure hope they start coming out soon. I don't want to pull the trigger on the Scarlet until i know housings are available for it. I reckon this is going to run 50+ K for the camera/lens/housing/lights
  12. Decompressing from DEMA now, heading back to SD.
    Pics of Scarlet look identical to EPIC. That means EPIC-X, EPIC-M and Scarlet are supported and interchangeable in DEEP EPIC. Confirming with RDCC.
    Orders for DEEP EPIC are being taken. $1000 deposit.
    J-
  13. Decompressing from DEMA now, heading back to SD.
    J-
    Pheww that's a relief !
    For me its only Scarlet and only Gates - nothing else will do!
    To answer my own question in my last post, yep a quick Google brings up tons of info.....to be honest I'd given up on Scarlet ever arriving so have not been following any of this - you can only get hyped so many times!
    Anyway, its real and its here. If Gates come through we are all set to go. Good thing is i have had long enough to save up the money ;-)
    J.D
  14. Decompressing from DEMA now, heading back to SD.
    J-
    Thanks John. From my handling of the Scarlet, the components are the same except for the big vent bulge on the top of the Epic. I doubt you'll be cutting it that close so it'll be fine.
  15. I think he's being sarastic Nick. :)
    oops :B):
  16. I think he's being sarastic Nick. :B):
    Heh, oops. Indeed :)
  17. Is that 20K for the Deep Epic???
    Dean
  18. Is that 20K for the Deep Epic???
    Dean
    Yes, just under, and includes:
    * DEEP EPIC housing
    * External monitor (your choice of 5.6" or 5")
    * Integrated REDMOTE Controller
    * FP80 or SP80 Port (acrylic)
    * PE286 Port Extender -- covers most lenses used. Longer / shorter available, price slightly different
    * Seal Check
    * Travel case(s). We're working hard to get the main housing case under the airline travel limit of 50lbs (US).
    Delivery: I expect shipments will start in December, and we'll start clearing our backlog. If you order now, expect February delivery.
    Question to all: a mechanical and servo zoom options are available. For manufacturing planning sake, I'd like to know your preference.
    J-
  19. John
    What lenses are covered? I assume the list for Deep Red is applicable? What about the Zeiss LWZ? Or is that a per request basis?
