TTL , Help Please
Started by Shadis ·
  • 10Posts
  • 10Replies
TTL , Help Please
  1. Hi
    I have a Sea & Sea housing for canon 5D Mark II and 2 Ikelite 161 strobes .
    Is there any way to connect them so I can sync them via TTL and not manual ?
    Tnx
    Shadi
  2. Hi
    Tnx
    Shadi
    Not so simple as it is for Nikon cameras I think. There are/were TTL converters for Canon cameras but they need 6 pin bulkheads. There are external converters still available from S&S but I don't know if they play well with Ike strobes
    Bill
  3. Hi
    Tnx
    Shadi
    If the Sea&Sea bulkheads for the sync cords are either "Nikon" or "Ikelite" format, you can use Ikelite's TTL converter. I use one on my Aquatica to DS-125 with Nikon bulkheads.
    JP
    Edited by johnspierce
  4. If the Sea&Sea bulkheads for the sync cords are either "Nikon" or "Ikelite" format, you can use Ikelite's TTL converter. I use one on my Aquatica to DS-125 with Nikon bulkheads.
    JP
    On a Canon? I thought they needed all 6 pins for TTL. Good to know
    Bill
  5. On a Canon? I thought they needed all 6 pins for TTL. Good to know
    Bill
    Oops. Can't speak to a Canon - -I did not know they needed all 6 pins. Shutting up now. :)
    However, a quick search of Wetpixel came up with this thread -- somebody here apparently had a custom-made TTL converter for Canon from Ikelite at one time:
    http://wetpixel.com/forums/index.php?showtopic=35344
    JP
  6. There are TTL converters for canon . Sea & Sea has them and so does Ikelite .
    The problem is that I have a Sea&Sea housing with Ikelite strobes and according to the web sites of each company the converters only work if the housing and the strobes are from the same company :
    Sea & Sea housing with Sea & Sea strobes
    Ikelite housing with Ikelite Strobes
    I posted this message to check if anyone tried mixed brands , it could be that they do work together and the only reason that the above companies don't admit it is a marketing strategy
  7. There are TTL converters for canon . Sea & Sea has them and so does Ikelite .
    I am not a Canon shooter, but I do have mixed brands. Nikon camera, Aquatica Housing, Ikelite strobes and they do have an adapter for TTL for my setup.
    In the link I referenced above the poster says he had a "custom" converter from Ikelite for his Canon. This would suggest they could make you a custom converter for your Ike/S&S combo, but I'm making a big assumption there. I would just contact them and ask:
    http://www.ikelite.com/web_pages/contact.html
    They've been pretty quick (within a day) getting back with me on questions in the past.
    Good luck,
    JP
  8. There are TTL converters for canon . Sea & Sea has them and so does Ikelite .
    I have a Heinrichs external TTL converter for Canon. If you have a 5 pin Nikonos to Ikelite cable, I am pretty sure (90%) that this converter will work with the 160 strobe. The problem as I stated before is that the housing needs to have a 6 pin bulkhead to get the camera signals to the converter. I could test this for you (I have a housing that has a 6 pin bulkhead) but I would need the proper cable. I think I can get hold of a 160 strobe.
    Bill
  9. I have a Heinrichs external TTL converter for Canon. If you have a 5 pin Nikonos to Ikelite cable, I am pretty sure (90%) that this converter will work with the 160 strobe. The problem as I stated before is that the housing needs to have a 6 pin bulkhead to get the camera signals to the converter. I could test this for you (I have a housing that has a 6 pin bulkhead) but I would need the proper cable. I think I can get hold of a 160 strobe.
    Bill
    Tnx alot , that would be great
  10. Tnx alot , that would be great
    Definitely curious as to the outcome of these tests, as I find myself in a similar situation (Canon 50D/custom Sexton housing for deep monitoring waterwork, Ikelite 50/51 substrobes). I was hoping to modify the housing to accept hotshoe-to-bulkhead connectivity with the Ikelite substrobes; however, Ikelite does not sell eTTL2 circuitry outside of their 50D-specific housings.
